AH FabricationsBadger5
Results 1 to 9 of 9
    Apr 2010
    Norwich
    7
    Safe Mode in Morning?
    Hi peeps
    Strange problem here, drove home last night, as normal, music on etc... parked up, went in, went to bed etc.
    Woke up this morning, started the car (seemed to take a little longer than usual to start upon turning key) and found my radio was in safe mode?
    I entered my radio code, which worked, radio back on etc, turned the car off, turned it back on and the radio is still working.
    Any ideas what happened? And no the car has not been tampered with or touched overnight.
    Many Thanks
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It sounds like the battery got very low on cranking the engine......do you use the car alot? if so get your battery checked it maybe on its way out
    Sep 2009
    West london
    379
    I had the same problem two weeks later battery totally gone
    I replaced with a new one been great since
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Cold = bad for batteries. The recent cold snap would have shown many car batteries nearing the end of their lifes, more than likely a replacement is needed.
    Apr 2010
    Norwich
    7
    Hmmm, now had it checked, sitting where it should be while off and running at 14.x when stationary and on...
    may have to take it for a second opinion?
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Its def the battery, mine was dying slowly over a period of months even though I was getting 12.5v stationary and 14v while running. It finally died and left me stranded, luckily I had jump leads on me. Changed the battery and the difference in crank speed was well noticable. Back to your problem, if it took a long time to crank over it always sent the radio into safe mode and switched the fans on, it was like disconnecting the battery due to the strain on it. Throw in a new battery and all will be rosy!!!
    Jun 2003
    World of my own
    9,813
    You can't judge a battery by voltage, you need a proper battery tester which measures the voltage with the battery under load. You can get 14v from 10 x AA batterys but I think they would struggle to crank an engine!
    Alex Turner
    Faster in reverse
    May 2010
    Stirling
    70
    u need to check it with a discharge tester mate
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    I'd say any battery giving 12.5v static is pretty poor anyway.....
    My battery in the audi reads 12.9v minimum ever, and the super light gel battery in my Mini never reads below 13.1v
