drfeelgood
So i took it into Audi due to the common problem of the stiff gearbox, or in my case 1,st 2nd and 3rd being stiff, and sometimes not even going in, also a lot of knocks, rattles and noises, as well as the smell of fuel....
3 days later here are the problems
oil leak near the cambelt/gasket (not 100% sure as dont have the paperwork)
Fuel leak from the injector seals (not " " ")
New fuel filter
Top mounts need doing
Both front shocks are gone
Both rear springs are snapped
rear anti roll bar needs replaceing
Wishbone bushes need replaceing, excessive play, (not 100% sure as dont have the paperwork)
clutch is not engaging and disengageing correctly due to wear to the springs, and is causeing not just a heavy clutch but also causeing the gears to be extremely stiff
i have only owned the car for 3 months since buying it from audis so called used and approved, should be getting everything but the clutch done threw the audi warrenty, thats if they accept it.
New fuel filter
