Yes he is a freelance guy who hires a ramp at national tyresthe guy who sorted it, was this a different garage?
Erm...im just happy its sorted now to be honest...Edit, just read you've sorted it which is a relief.
Perhaps get a letter out to trading standards to vent some anger? Not sure how far you'll get, but worth it for ten minutes write.
ALL SORTED!!
Great guy who did a full geometry check, even moved the front chassis as it was 1mm out,
He has never seen a steering wheel that far out, apparently by warming the tie rods and not letting them cool back down before adjusting.
The car is a different animal now and just oozes confidence.....
He has got every adjustment exactly the same left and right.
Well happy...
Yes it will be tomoz night as it is at work..You got a scan of your final settings? Would be good to see.
£100 but that was centralising the chassis, def worth it, i would recommend it drives like it is on rails now....How much did they charge to set it all up properly mate?
Thanks mate, and they will never rust....cool, thanks
btw; had all my suspension bits fitten this week, the guy at the garage was well impressed with your shiney Tie Arms:icon_thumright:
Yes the wheel will be central if they are doing the job correctly.. 4 wheel alignment(edit sorry)
Im concerning the wheel straightness. Basically its atleast 2 inches (right hand down) to drive straight and therefore can then correct this?
If so, how? Re-alligning the tracking?
