EM TuningVolks Autos
Results 1 to 7 of 7
    May 2010
    19
    Drive train squeal PLEASE HELP !!
    iv got a 99 s3 and have got a squeal its like a brake squeal but its not the brakes iv replaced front discs and pads also rear discs and pads aswell as a sticking rear caliper even done a fluid change.
    it only happens when its warm and only happens between 15-25mph
    some one somewhere has had this problem and i need to find the solution its driving me mad !
    please please please can some one help me
    Dave
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Have you checked that the disc guards are not touching the discs anywhere?
    May 2010
    19
    yes tryed that mate even took the front 1s off for a while
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    could it be something rubbing on the propshaft/drive shafts? like a heat sheild
    May 2010
    19
    im gunna take a look at wheel bearings abs rings prop shaft and drive shafts on wkend i gotta find it cant take it no more am just hoping some1 has had it and solved it and could help me thanks for the advice tho
    Aug 2010
    1,540
    not a brake binding somewhere?
    May 2010
    19
    thanks for the replys guys it ended up being the top cat heat shield had broke away and was just about touching the prop bloody annoying just ripped the lil sucker off prob solved lol
