EM TuningJMB Retrofits
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By JamJay
Thread: S3 No boost
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    S3 No boost
    Hi Guys
    Had my S3 remapped 3 months ago, since then its been nothing but trouble, have had to replace turbo intake pipe, breather hose left of inlet manifold, breather hoses underside of inlet hose, mass air flow meter. Finally got it running at full boost last night after the inlet breather hoses got replaced.
    Can to the car this morning and have no boost at all, turbo is not spooling, it was fine when it got parked up last night. Had a quick look while on route to work this morning but cant see any hoses leaking. Scanned the car and its come up with a DV fault.
    Question, If the DV was buggered would that stop it boostng?
    How do i tell if the N75 valve is working?
    Car is a 225 BAM
    Cheers Jacko
    Black S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    get it scanned mate...could be anything
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Its not putting up any codes apart from DV, First thing i did was scan it with a code reader. Can DV Failure cause no boost?
    Black S3
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Remove the T.I.P and just check if the turbo is turning free
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Turbo spins fine, has a little play in shaft but nothing major, would think its a vac hose or DV problem. So can anyone tell me if DV is dead would i suffer from no boost?
    cheers
    Black S3
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Why dont you take your dv off and check it. If you push the piston up and put your finger over the vacuum the piston should stay up, when you let go it should go down. This is what some one on here told me the other day. check thread 'Why forge 007p'. I checked mine and it when down half way so dont know if i have a leak or not?
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    All sorted now, Turned out nothing to do with the DV.
    Black S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    ?? come on then....lol
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Lol I love threads like this. I have an issue with my car and Google throws up all of these threads but no-one concludes lol.
    antwon likes this.
    S3 Paul's Avatar
    Oct 2006
    2,764
    Yes . lovely, use the forum to search for threads that help... but when you find it to be something not covered....
    Leave us all hanging
    Noggy Blue 2001 S3
    May 2011
    6
    i got the same problem.. Got in my car earlier n no boost atall. switched my engine off. n back on now its fine :s??. Any ideas??
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,274
    Quote Originally Posted by antwon View Post
    Your car has thrown a fault that's triggured soft limp mode, this puts the car down to 6psi of boost max. By turning off the car and on again it will clear the limp mode until the fault gets flagged again.
    It will be difficult to determine what the problem is unless you get your car scanned with VCDS.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    May 2011
    6
    Ok thanx for that w3sty! So were do i get it scanned?? Is it just a diagnostic?? :s
    May 2011
    6
    Oh and i was told it could be the air flow metre... Is that pos?
    Westy's Avatar
    Dec 2008
    17,274
    Yeah you just need a diagnostics scan. Audi will pull down your pants spank you and call you Susan A.K.A charge you £60ish!
    Your best bet will be to look on the map in the following link and find your nearest friendly ASN member who has a copy of VCDS. PM them and ask them nicely if they wouldn't mind scanning your car at some point.
    http://www.audi-sport.net/vb/vcds-fo...%2A%2A%2A.html
    S3 Build Thread
    May 2011
    6
    LOL!! ok thanx for your help mate.
