Haha Nattie that is just what i have done.Not taken it out yet tho to hear what it sounds like.Does it really reduce engine temp??..how would i know if it does?.
I took mine off. I wonder if you can use Dynomat underneath there? Or is it not heat resistant enough?
Welly did you also remove the rubber strip at the back of the bay? Did that have any ill effects at all?
I might rip the sound proofing out of my bonnet this evening.
Theres a strip along the slam panel and rear mate.think its for rain water to stop getting in or to stop the bonnet banging about??..
Yep, the rubber strip is gone also. No ill side effects so far and it's not been there for several months now....
IATs are definitely cooler though.
Prawn, do a before and after IAT log - I'd love to see....
I'll give it a shot when I get the chance.
You guys are going to laugh at my epic 64 degree IAT peak!
Wow..... was that whilst moving?
Yea, 18psi through a standard single SMIC from my ko3S. 64 degrees was reached after a pull to redline through 1st, 2nd, and 3rd.
it's regularly 57+ though after a full throttle pull, both with the cold air induction kit in teh bumper, and now with the jetex cone.
FMIC required desperately!
I would not think this would be to good for the bonnet paint,, the constant retraction and expansion , it must get red hot above the turbo....
And is it not a fire retarder too....Very good point! I wouldn't want to mess the bonnet up.
