Badger5Volks Autos
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Aerial Reception!!
    Is it just my car or is the Aerial reception really crap??..
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    Woody001's Avatar
    Jan 2006
    Bedfordshire, UK
    12
    Hi,
    The reception on my A3 was terrible, inspection revealed that it had corroded quite badly inside the whip itself, I replaced the whole aerial and can now get stations I never could.
    Stoke Audi supplied the replacement.
    Hope that helps,
    Ian.
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    What bit did you replace mate,just the aerial bit that you can unscrew??.
    Woody001's Avatar
    Jan 2006
    Bedfordshire, UK
    12
    No, the whole lot - Mount and whip.
    I tried to unscrew the whip and it wouldn't come off, trying to rotate it resulted in corrosion falling out of it.
    Roof Aerial - Stoke Audi Parts
    Does your unscrew or show any signs of corrosion?
    Cheers,
    Ian.
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Yeah mate it does come off,it does have a little corrosion.ill have a clean up and see if any better.ive also tryed a different whip but still the same.
    Oh also did you fit the new mount yourself?
    Woody001's Avatar
    Jan 2006
    Bedfordshire, UK
    12
    Yes, fitted the mount myself, the hardest part was getting the aerial lead joiner apart, I dropped the headlining at the back after removing the side trims which made it loads easier. You can just access it through the rear interior light hole.
    If you need further help just drop me an email.
    Ian.
