Chris NottSky Insurance
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    stuck lambda probe
    trying to remove the post cat lambda probe from its exhaust slot but no luck, after 9 years in there its not coming out. tried WD40 and warmed up the exhaust...
    Any ideas on how to free up a stubborn stuck part?
    Thanks..
    S3 Paul's Avatar
    Oct 2006
    2,759
    Mine was stuck too.
    I was advised to drive the car... which would heat the area and then borrowed a lambda probe spanner,
    This worked a treat.
    Noggy Blue 2001 S3
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Paul, thanks
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Go and buy a hand held blow torch from your nearest DIY joint. Fire it up, heat the thing right up. She'll come out then. The benefit being you get concentrated heat this way.
    Handy to keep as well for future things (such as stripping paint or varnish in the home), and also useful for lighting bonfires....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
