AH FabricationsVolks Autos
Results 1 to 30 of 30
Thread: Why Forge 007p
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Why Forge 007p
    This may seem like a silly question, but why does everyone go for forge 007p? (or even any other aftermakret dv)
    Are there any gains over the standard dv? or is it just a case of the standard ones seem to fail ?
    Im trying to figure out whether or not to get one but there is nothing wrong with my standard dv(as far as im aware)so don't know if there is any point.
    Thanks, Lee.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    Theres no power advantages the 007P is just a better design and more reliable, but many run the standard DV with no problems, and you can replace a a standard DV about 3 times for the same cost as a 007p. 007p does look nicer though .
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Oct 2010
    35
    They leak over time.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    the spring can stick and the DV will be at least 7 years old
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    I think most people go for this particular DV as it is specifically designed to operate with the VAG engines (Closed Loop / Recirculation Design) whereas some other makes of Uprated DV's don't work in the same way. I have one on mine with the YELLOW SPRING and it's been absolutely fine. Some people also look at the FORGE SPLIT-R as well which can give you the "whoosh" noise and offers the flexibilty to cap it off to make it quiet but I've heard that these are not as good to be honest.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Plus there is the sheep factor......lol
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Sheep syndrome usually follows (get it?) on from success, for example the RSTT wheels looking superb.
    The 007P is still a diverter valve, rather than an atmospheric dump valve. It means it will not cause any running issues with the VAG engines. They are reliable and can be uprated (spring colours) to allow for higher boost pressures from modified cars.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by JD09 View Post
    jd what happened to your remap, filter and dv?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Exactly my arguement for the 007P. It gives adapability over it's life. I have had the same one going from 210 bhp, to 260 bhp, and onwards past 300 bhp. Same valve, different spring.
    It just works for me....
    Homer Simpson
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    It's Forge. Forge is like God.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DJ_Troopa View Post
    EDIT: Forge are reading this right now....
    Homer Simpson
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by finesse View Post
    Unsure on where the car is going still, but seems to be head to just standard parts only chap. I have a green cotton filter, but for now, have no need for it to be mapped
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Is there any way of testing the diverter valve, i have done boost checks on the lower part of my intercooler pipework but the upper bits where the dv is doesnt work because the air just escapes from the airbox/filter?
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    lee
    To test if your DV has failed remove the DV, press
    the diaphragm up, put your thumb on the top nipple, and then release the diaphragm. There
    should be suction created on the top of the DV that prevents the diaphragm from returning. If
    there is no suction then the diaphragm is leaking and the valve should be replaced. IF the
    valve is good, check the VAC line leading up to the valve for any cut’s/ tears.
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Thanks for that finesse, i will give it a go tomorrow. Depending on what happens ill get a 007p. Does anyone know a cheap place to get the 007p? Also my car is at stage 2. Shoulld i get a yellow spring?
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,324
    yes, yellow spring for you sir
    Sep 2009
    738
    Awesome GTi were doing 007P for good prices on their ebay site, thats where i got mine, try here:- Forge 007P Diverter Valve VAG 1.8 20v Turbo - Awesome on eBay (end time 06-Nov-10 08:21:48 GMT)
    S3 Andy's Avatar
    Mar 2007
    70
    Awesome do their own branded one that works out about 20 cheaper than the forge one.
    Awesome - Awesome/Forge 1.8T+2.7T Diverter Valve
    Awesome - Forge 1.8T+2.7T Diverter Valve
    As far as i know it's made by forge and is the same thing - atleast that's how it was sold to me.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    or go to JBS who 9/10 will beat the awesome quote and you dont end up with a silly 007p with a MASSIVE Awesome logo plastered all over it
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Quote Originally Posted by 1animal1 View Post
    I bought mine from JBS at Inters earlier in the year.....
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    I got mine from Reuben @ Tuningwerkes. Tell him Troopa sent you. 0208 681 0208.
    S3KO4's Avatar
    Aug 2009
    London
    850
    I have used forge as well as standard and other after markets. but went back to standard. as it does the job just fine. I am runing full stage 2. with no issues for over a year and stage one before that. the car keeps the boost up with no issues. plus the rs4 2.7T uses two of these so If there was a fault then AUDI would have redesigned something stronger. ps I have seen them on another RS4 runing close to 600BHP.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    I may pop into tuningwerkes as it is only down the road from me. Are you local to croydon Troopa?
    I took my dv off today and had a bit of a play, when i push the piston up and put my finger over the vacuum.. the piston slips down hhalf way then holds, then when i let go it will drop the rest of the way. Is this normal or is it leaking?
    S3ko4 i remember you saying at ace cafe you had a standard dv, but at the moment i seem to be having boost issues and am trying to find if the dv is the problem, my boost seems to hit 1.4 bar then drop to 1.0 straight away. Some times it drops to about 1.2 and holds. Although today i see it go to 1.5 bar and drop to 1.2.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    lee, what good vag mechanics in SE London?
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    I know a guy in croydon that does golf stuff but is very good with 1.8ts. Other than that i think amd in woking is the closest that i know of.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    tuningwerks seem to have good reviews
  28. #27
    Lee172's Avatar
    GT3071
    Jul 2010
    Wimbledon
    431
    Yes they do but i went there to get a trial map before which ended up being more hassle than it was worth. I couldnt comment on the actual mechanical work they do though.
  29. #28
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Reuben at Tuningwerkes is a top guy. Tell him Troopa sent you and he'll look after you. I've known him for years now after he worked on my bro's car back in the day and he's good friends with couple of my friends.
  30. #29
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    troopa, is that your street name lmao
  31. #30
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    I'd recommend Dean at 4rings (www.4rings.co.uk), they're a mobile outfit based near dartford so not far from you. Very good service and good prices too.
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
