Monster MotorsportChris Nott
Results 1 to 9 of 9
    Sep 2010
    498
    1.9 TDI weird noise from passenger side
    Its mainly apparent when the engines cold but can still here it when its warmed up. Sat inside the car theres always an odd noise as the engine accelerates and then changes gear its like a rubbing/scrapping kind of noise. Anyone else had this?
    ptr
    ptr's Avatar
    Aug 2010
    129
    does it change with speed/revs?
    Sep 2010
    498
    Yes, it gets louder but stops when I put the clutch down.
    Sep 2010
    498
    Took it to an independent audi specialist today and was told it was the cambelt casing was a bit loose and touching the pully. I was told this would be about 195 to fix!! Is there any way I can do this myself?
    Sep 2010
    498
    Anyone?
    Sep 2010
    498
    Anyone??
    Sep 2010
    498
    Can anyone help with this? Can I even run the car with the covers removed?
    S3KO4's Avatar
    Aug 2009
    London
    850
    time belt? if it is then it's not an easy job for 195 I would give it to a mechanic to do the work. it could be the fanbelt/alternatorbelt the visible one which also sits on the driver side. you can check this yourself. if it has lots of cracks ect. thats a lot eaiser I would say 50 pounds all in.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    ptr
    ptr's Avatar
    Aug 2010
    129
    Quote Originally Posted by doublem_1 View Post
    If it stops completely when you put the clutch down then how could it be the cambelt? Doesnt make sense to me but then I'm no mechanic
    I would take it to another independent Audi specialist and get a second opinion, 195 is a lot to spend if that's not whats causing it.
    Just in case it is the cambelt I would try and not drive much until it's sorted.
