Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    Jul 2010
    111
    Car will not start, help please
    Hi Guys,
    Strange one, started my 2001 amk s3 this morning, started fine with no problems. Drove it up to my mums house turned it off, came back to it and it fires but then just dies and will not hold revs?
    any ideas at all?
    Fuel pump primes
    cheers
    AudiMafia's Avatar
    Apr 2009
    London
    403
    check the connector to the air filter.... sometimes its got to do with air n the fuel not enough air going through i had the same problem with my previous car
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Need more info bud, i take it when it doesn't hold revs it is misfiring? When it fires up how long does it run for?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    yellow light flashing on dash? Dash lights working?
    Jul 2010
    111
    Thanks for the replys guys, this is a real; weird one. Basically it was showing on vag com that the immobilizer was armed, hence why it would not start.
    The only thing i did was put the oil sensor plug back on that had come off. So i thought i would take it off again, cleared the codes, Starts perfect????
    Is it maybe the wiring in the oil sensor plug shorting something out?
    When i had it plugged in, every time i would start it it blew the 5A dash board fuse so i couldnt see anything?
    any help would be great
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Just check the wiring back to the loom, have you got an old sensor you can plug in and just earth it to the block, and see what happens...
    AudiMafia's Avatar
    Apr 2009
    London
    403
    shud be the fuel pump when i had a similar problem with my 8l the AA man trailed the car behind his aa van and took it up hill down hill and waved it around then it started working, i did so many things to start the car,jump leads, batterie change but no luck and everytime i disc the battery the dash lights wont work no idea but every time that happened i had to do about 15miles without stopping so the dash lights would start to work
    Jul 2010
    111
    s3 dave, no i havent unfortunately, when the plug is of the wire is so stretched, like really tight. Has anyone else had a problem with the plug being pulled off?
    im guessing its when the engine rocks that its happening,
    Thanks guys
