Sky InsuranceEM Tuning
Results 1 to 11 of 11
    Oct 2010
    38
    Replacement recirc valve, is it right for my car?
    Hi. Iv just replaced the recirc valve with a copy of the Turbosmart plumb back one. It's exactly the same as I used to have one on my golf. On the top it has a bit you can turn to softer or harder. After fitting it I set it to harder and took it for a drive and it's making that weird fluttering sound when letting off to change. It's an s3 225 model remapped but only to around 260bhp so shouldnt be a crazy amount of boost. What would you recommend having it set to? Soft or hard, how can I tell. What should it be sounding like? It did sound similar on my Golf tbh, had that set to hard but that was running very high boost. Im not even sure whether you would normally be able to hear it but iv put a k&n panel filter in and put some holes in the cold side of the air box. Just don't want to be damaging anything by having the spring set too hard. Any advice would be good. Thanks alot. Steve
    Oct 2010
    38
    Anybody have a clue?
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Is that turbosmart definitely a recirc dv??
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
    Oct 2010
    38
    Yes indeed. Should it make a fluttering noise?
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Nope they shouldn't flutter. Split pipe going into the dv by any chance? Get a Forge 007p and you won't have to worry about anything matey.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    fluttering is usually a split/loose pipe, its not good for the turbo
    Oct 2010
    38
    Wouldnt it bring up a fault if I had a split pipe? Is that the one going in from the side?
    Oct 2010
    38
    What springs are they on your Black s3 DJ troopa? Looks spot on. Iv just ordered the same wheels but in black with a red lip, and I have some -30mm apex springs to fit.
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Quote Originally Posted by L4V15 View Post
    They're AP coilovers mate.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    I would say you have it set too hard and it's compressor stall you are hearing. Thats not good for our small turbos, i would slacken it off. Have you a boost gauge?
    Oct 2010
    38
    Na I dont have a boost gauge. Iv tried it fairly soft today and it's still making the fluttering noise and iv checked the pipes hoses etc and definitely no splits
