AH FabricationsSky Insurance
Results 1 to 10 of 10
    Apr 2009
    17
    Juddering on acceleration
    Hey guys,
    So last night I drove 70 miles to Bristol Airport to pick up the girlfriend, everything was fine on the way there (except the middle lane hogs on the motorway!) Stopped at the drop off point, went in collected the gf, got back in the car, back onto the main road which is when the problems started. Upon acceleration the car seems like it is misfiring, the engine light was flashing on also. I'm guessing that this would be the coil pack? Just posting so that somebody could confirm that it is, or maybe figure out it's something more sinister? If it is the coil pack, how much am I looking at?
    Ben
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    most likely coilpack.
    what engine do u have? if its an AGU its more likely to be the ignition module
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Apr 2009
    17
    Erm not sure of what engine it is, it's the 210bhp if that's any help, 51 plate. I'll find out when I get home
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    It will be the AMK engine and it could be the coilpack, did the engine management light come on?
    See if you can get the car scanned,that shold tell you straightaway.
    Chugger
    North Devon
    2,716
    definately sounds like coilpack. When its warm push them all firmly down as they some times have a tendancy of popping back up if they have been removed for any reason.
    57 A3 2.0 TDI Sportback (140)
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    maf, worth a look
    S3KO4's Avatar
    Aug 2009
    London
    850
    Coil pack, most def, to check remove the engine cover and shove the hoses out of the way, turn on the engine, one by one start removing the connection at the back of each coil pack (only for a few sec) and reconnect it if there is no change in removing one then thats likely to be the faulty one. however if the engine gets worst then thats a working coil pack.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Apr 2009
    17
    Just had a quick look at the coil packs on my lunch break, starting from left to right, the first 2 seem to be fine, the second 2 are covered by some hosing and a box that is bolted on, so I will have to look at those 2 when I finish work. Also I was just wondering how do I remove the faulty coilpack? from the quick glance just now I can't seem to find any way of removing them? cheers
    jimmp's Avatar
    Feb 2009
    Edinburgh
    146
    Hi Banjonez-
    you just pull 'em out!
    There is actually a removal tool but it's just a "puller"- you can do it by hand...
    JimP
    Apr 2009
    17
    Cheers for all the help guys
Tags for this Thread
