S3 CYP
This is the first problem with my car (2002 AMK) in the three years I have owned her where I have had to call the AA for a tow home.
Sat in traffic the other day and I noticed on the liquid gauge that the temp was raising to about 100 which on a hot day is normal - when there was a break in the traffic the temp would go back down to 91 - 92 .
I then hit some really heavy traffic ands when I noticed that the temp had risen to 108 and thats when the needle on the dash started to rise also.
I pulled over to check what was going on and did the normal checks, fuses were ok, no loss of coolant sitting just above the min mark, water pump (metal impaller) and therm were replaced 15,000 miles ago on the cam belt change.
Obviously the fans were not coming on but they were not seized and both could be spun by hand quite freely which prob means s**t with and Audi.
Did a bit of searching on here and found that the problem might be the Fan Cooling Module - so popped to Audi (got bent over for the part, even with a discount) changed it today and took her for a test drive and guess what - fans still not coming on!
The Air Con fan is not coming on either which made me go down the cooling module route if thats any help.
Any ideas fellow owners?
Costa
Costa
