Volks AutosEM Tuning
    S3 Harj's Avatar
    87
    Changing a xenon bulb - Help please
    Right.. have the new bulbs but not too sure how to fit.
    I've managed to get into the headlight cluster from the back and twist the connection off. Now there looks to be a black holder in place which i dont want to force out the wrong way, i'm told to twist to release the bulb, but which way?
    AUDI S3 8L - AmD'd
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Detach retaining ring -1- for gas-discharge lamp by turning anti-clockwise
    Here are the instructions - Download Xeon_Headlight_repace.pdf from Sendspace.com - send big files the easy way
    HerefordQuattro's Avatar
    Hereford
    303
    guessing they genuine original HID's so will be same fitting as mine (I hope) the high voltage connector twists off (take care very high voltage do not turn lights on with this disconected as it will arc!!)
    Then you are left with a black plastic holder which you twist anti-clockwise to remove, i know what you mean about breaking it as it really isn't a nice design of holder and doesn't feel like it wants to un-screw (feels like it's about to shatter the whole lot in your hand) but trust me it only takes a 1/4 turn and it will be off.
    Obviously don't touch the bulb (even more important with HID's than halogen) to put back together is again quite naff feeling, the bulb doesn't want to sit sweetly and you need very nimble fingers to hold the bulb in place and then delicately manoeuvre the black plastic holder over it then twist back into place (the holder has a 'TOP' mark on it so line it up to twist up)
    crap discription but good luck
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    S3 Harj's Avatar
    87
    thank you guys.. great info.
    The only bit thats confusing me is the anti-clockwise rotation. The diagram shows both the gas connector and the black holder twists off in a anti-clockwise direction yet the arrows are pointing in differents ways?????
    If im standing at the front of the car with my head under the bonnet over the right headlight the gas connector comes off in a anti-clockwise direction, would the holder come off in the same way?
    AUDI S3 8L - AmD'd
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    LOL, you are right...
    If you look at the power connector from the side (with a mirror maybe) you should see the direction in which you need to twist them. The holder will be in the opposite direction I guess.
    S3 Harj's Avatar
    87
    Thanks again guys.. all done this morning.
    The first one took about 45 mins. But once i worked it out and got to grips with it the second bulb only took 5 mins.
    S3 has its blue eyes back. Sorted..
    AUDI S3 8L - AmD'd
