- Joined
- Nov 11, 2009
- Messages
- 10,099
- Reaction score
- 739
- Points
- 38
- Location
- west yorks
- Website
- www.stainless-engineering.co.uk
if the s3 had tits we would all be ******.....
People need to stop thinking there engines are going to fall apart any minute lol. Ye rods fall but its a very small minority that do and they tend to be running quite a bit more torque and power than the standard engine spec.
Im doing a con rod FEA assignment in uni now and wanted to do it on a S3 rod but havent got the dimensions on one to measure accurately.
Nathan
No, not dangerous. However, REVO maps are known for their aggressive delivery by all. Much less progressive than other maps, and that's due to the torque production. As Jo said, early and harsh torque isn't the best for the rods.
Many people are using, and have used, REVO maps for a long time with no issues. But out of the generic maps available, I would say they are the most likely to cause issues. That's not to say will.
some points to consider.. based on my own experience and some very good engine builder advise given tome.
cylinder pressures are large... mine would have been >3000psi on ign timing I ran
get your calculators out and see what forces that introduces, and think a 4 degree ign advance added 400psi more
cyclic at your rpms, up and down..... I have posted the numbers on here before somewhere..
{why is this forum so slow when i type this is sits several secs before the words appear?? very annoying!)
Likely det and boost combination caused the muchos cylinder pressure to bend the rod..
think in terms of >2500psi cylinder pressure during combustion to put it into prespective, 7.9sqin area, x 2500 = 19901 lb force = 9046Kg of downward force..........vs the ickle Rod
i am looking at getting stage 2 revo map or custom map from wayne at chip wizards along with fitting full exhaust system and 4 bar fuel regulator would be looking at around 240bhp on my audi a3 1.8t quattro.
would ppl recomend rods or still be ok on standard rods as had a look at the engine in terms of taking it out seems a real pain in the ***
excellente i thought i read it somewhere. thanks for reassuring me so can relax a little now
why the **** didnt they make them stronger for s3's than the 150?
for the design spec of 225bhp they were adequate
later models get 19mm rods, and newest got sintered 19mm rods - EAK!
no I dont have timeAs i pointed out previously, these rods are largely unchanged from the very earliest 058 blocks.
Bill, did you get a chance to compare a 16v Golf rod with an S3 one?
sintered as in made from a compressed compound? wah thats crazy
