Results 1 to 14 of 14
    May 2010
    colchester
    223
    A3 juddering problem :( Help needed by the audi brainers
    Would like help with any body who has had this problem or no of anybody who has fixed this,
    I have a 1998 Audi A3 1.8T petrol (AGU engine) the car has just done 123,000 miles
    I can be driving along normally then for no apparent reason when I accelerate the car hesitates and feels as if its missfiring,this was doing it about 4months ago then stopped and now has come back and is a real pain in the a** to drive help would be great
    It lasts for varying amounts of time then disappears. When the car is stationary with the bonnet up I can see the engine appear to misfire causing it to jerk every so often causing a popping/spluttering noise from the exhaust. This doesnt always happen so cant put my finger on what it is.
    A couple of times I have been sat at lights and the revs drop to almost stall point but then it corrects itself. last week it was really bad,
    I have had a new maff fitted about 5 months ago so hope it is not that,also things i have done to my car full servise 8,000 miles ago,exhaust cat back,piper-cross panel filter,remap and 007p d-v,
    Would be great if any body could help me on this thanks alot
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    VAGCOM (VCDS) in the first instance to see if there are any fault codes...
    There are a couple of possibilities here... air leaks (vacuum/boost) and ignition.... when was the last time the plugs were changed? I would also check the gaps... should be 0.7mm...
    Could possibly be a coil pack but they just normally go and stay gone... I would check for vac leaks (more likely at your mileage) and check the plug gaps (assuming they have been changed recently)
    Pipes usually split under the inlet manifold... PCV being the favourite as they carry oil and it rots the rubber...
    Get fault codes checked first though...
    <tuffty/>
    May 2010
    colchester
    223
    No fault codes showing,no leaks i can see as boost gauge showing the same? millage didnt think it was that bad ???
    Allso been told could be the ignition on side of air box,could this be the reason ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Could be... there is an ignition amplifier pack on older A3's thats attached to the airbox... could be that...
    <tuffty/>
    May 2010
    colchester
    223
    Ok will give that a clean tomorro thanks
    talentwalsh's Avatar
    May 2010
    Galway
    139
    No 1 coil went on mine and caused similar problems but it was really bad. Horrible spluttering, misfiring and the likes. The coil was actually popping out its seat and causing the engine to run on 3 cylinders. Could this sound similar?
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    i had the same thing on friday it was my ignition control module. changed it in 30 seconds and problem went away. coilpacks rarely go on AGU's. The ignition control module cost me 69 from eurocarparts. They call it just "ignition module".
    Cleaning it wont help by the way. but u can keep the original heatsink aswell. Just be careful not to knock it on anything when fitting its quite sensative. i put some of my cpu thermal paste between the two aswell for extra cooling.
    hope that helps
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    OK.
    I'd go with the ignition output module also.
    It's called the Power Output Stage module N122 (p/n 8D0 905 351 (A4) or 4D0 905 351(A3))
    There is a guide for testing them here:
    DIY test of power output stage/ignition amp module N122 (long & BWW) - AudiWorld Forums
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    May 2010
    colchester
    223
    Thanks guys will look tonight when I get in for a new one thanks alot
    Aug 2013
    can you remove this ignition module as my car is causing similar problems, can I not just put a induction kit on
    Aug 2013
    36
    See this sounds like the same thing that is happening to mine ATM, so will it be coil packs or ignition amp, plugs just been font on mine, also do u get a bit of a strange start when first turning the car ova?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by Elitecarz2011 View Post
    No... you can't just remove the ignition amp... if its faulty you need a new one..
    <tuffty/>
    Yonner's Avatar
    Feb 2009
    Oldham
    139
    Try unplugging your MAF , it will throw lights on dash but they will go when you plug it back in , mine was the same , I unplugged MAF and drive the car , it wouldn't boost much but drive very smooth through all gears , as soon as I put new MAF on and all was ok !
    Aug 2013
    Starting the car is fine. it doesn't judder on a start engine and does it a lot on motorway, it feel like its loosing power, Iv been told its ignition module because its not getting the right air in.
    Iv already spent a lot of money on this car and its been a beauty, my mechanic also cant figure out, and iv got everyone saying all sort.
    Coil packs, ignition module/amplifier, it need a remap.
    Don't know what to go with...
