AH FabricationsEM Tuning
Results 1 to 25 of 25
    S3 Paul's Avatar
    Oct 2006
    2,759
    10mm spacers up front??
    Who runs with 10mm spacers upfront?
    Ive just fitted mine and as my car is lowered it seems the wheel/tyre sits very close to the arch.
    I like the look but if it drives funny or catchs on the archs... they are coming off.
    The days of scraping are long gone for me.
    Does anybody else have this set up??
    Im running 15mm spacers at the rear and have standard wheels on my S3
    Noggy Blue 2001 S3
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Well the catching is probably because the offset of your wheels, and how low your car is. 5mm spacers might be adequate enough for you.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    I'm running 15mm up front Paul, lowered with 18" rstt's et33, no catching and drive fine
    S3 Paul's Avatar
    Oct 2006
    2,759
    Well i hope mine will be fine too.
    P.s... im watching the wheels you sent me a link to...
    There seems to be a lump in the arch liner around 11 oclock on the wheel as you look at it... if that makes sence?
    That seems to be the closest point. ive got adjustable coil overs so could stiffen things up a little to help? But i dont want to drive a brick every day. Ive got a mk2 golf for that.
    Noggy Blue 2001 S3
    DJ_Troopa's Avatar
    Back in a turbo!
    Oct 2008
    West London
    1,735
    Visit DJ_Troopa's Instagram Channel
    I'm running 20mm on rear and 15mm on front. No problems at all. The arches are so wide from the inside even i could hide inside it! You have nothing to worry about.
    Inferi Black Cupra K1
    S3 Paul's Avatar
    Oct 2006
    2,759
    I will hold you to that!
    Seriously changed the look of the car.
    I like it
    Noggy Blue 2001 S3
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    I'll take a pic of mine on full lock tomorrow Paul, you should be fine running it reasonably low without it rubbing, bear in mind if the tyres are worn now, it may rub when you get new ones lol
    P.s.. get those wheels, give them i nice refurb and be the first to get a set on the 8L S3 or somebody else might get them
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ive got new tyres on... so hopefully it will be fine,
    Also... regards the wheels... im on with making adapters now... if not those wheels... i have another first in mind
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by DJ_Troopa View Post
    Same here no issues as yet..
    S3 Paul's Avatar
    Oct 2006
    2,759
    Just out of intrest... what measurement do you get from bottom of the wheel rim to the edge of the arch?
    I think i may be lower than most. so may need to decide... raise the old girl or remove the spacers????
    Noggy Blue 2001 S3
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Quote Originally Posted by S3 Paul View Post
    You can tell me if you like
    S3 Paul's Avatar
    Oct 2006
    2,759
    Out of intrest... what do people get if the measure from the bottom of the wheel RIM straight up to the wheel arch?
    Mine measures 57cm up front...
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    I will post mine tonight Paul,
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    i think you should be measuring from the centre of the wheel to the top of the wheel arch to get a decent comparison, else your wheel diameter will affect the measurement as well
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    S3 Paul's Avatar
    Oct 2006
    2,759
    I realise this . So ye unless running 17's maybe best to work from centre of hub/wheel
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    or just knock 12.5mm off for 18,s lol
    S3 Paul's Avatar
    Oct 2006
    2,759
    Did think that but wasnt going to complicate things.
    I drove to work in a completely different way to usual..
    I actualy aimed for the dips in the road to see if anything rubbed.
    So far so good.
    I may resort to sticking a bit of masking tape over the nearest point of the bodywork/ arch liner to the tyre and go for another drive...
    Noggy Blue 2001 S3
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    12.7mm
    Alex S3 AMK
    S3 Paul's Avatar
    Oct 2006
    2,759
    Seen as it will be measured with a tape or a rule i will allow a tolerance of +/- 0.2 mm.
    Just this once mind !
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by Cookstein View Post
    12.7mm
    correct, i was allowing for brake dust on the alloys..................
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    lol
    Alex S3 AMK
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    lol
    O/T U.P.S Have just picked your bars up,
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    thanks Dave, i'll track it now
    Alex S3 AMK
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    i have got 55.5 cm so a fraction lower factoring the 18 inch
    S3 Paul's Avatar
    Oct 2006
    2,759
    Nice one.
    Thanks dave.
    Well i havent had any nasty noises yet so... fingers crossed its all good.
    Noggy Blue 2001 S3
