    Dec 2004
    A3 1.8 SE engine rattle
    I have got an A3 1.8 SE which developed a rattle that has got worse over a
    period of time. The rattle starts when I begin to accelerate, after 1500 revs it
    dissappears.
    I was told it was the Cam Belt whiplashing and it needed changing - I have
    since had the Cam Belt, water pump and the bearing changed and the noise is still the
    same.
    I did not have the tensioner which is seperate to the tensioner bearing changed because I
    was told it was ok.
    Any ideas as to what the problem might be will be appreciated.
    Amanda
    Post Whore
    Jul 2004
    Southampton
    1,747
    Re: A3 1.8 SE engine rattle
    Should always change the cam belt tensioner while changing the cam belt - Its not essential but why NOT bother seeing everything is being done in that area.
