Volks AutosAH Fabrications
Results 1 to 13 of 13
Thread: Haldex service!
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Haldex service!
    I need to do a haldex filter change on my S3, i am quite mechanically competent so going to do it myself. I have access to a 4 poster ramp, and most tools required, but wonder if you guys have got any hints, or must haves before i start.
    I've had a read using the search function, but cannot find any instructions, only specifications. I will be taking pictures, and making notes on tools required so i can hopefully help others.
    Like i said, any advice, links, or tool requirements would be much appreciated, as i will be doing this free hand...
    It's better to burn up, than to fade away...
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    You'll require the haldex tool, think its available on ebay and from GSF, euro car parts:
    HALDEX OIL FILTER TOOL T10066 VW R32 AUDI S3 - AUDI TT on eBay (end time 09-Oct-10 00:48:51 BST)
    I think its availble cheaper through ECP or GSF
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Got the tool when i bought the filter and oil, thanks anyway.
    The diagram shown gives you an idea what i'm looking for, however i have had a look at it today, and i can't even see the filter...
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Quick search on the forum and I found this link:
    AudiWorld Tech Articles
    May 2010
    139
    The filter is on the right hand side of the haldex unit when your looking at the car from the back, The drain plug is more towards the left.
    Use a torch and shine it up, if your lying under the car with the haldex unit directly infront of your face, legs sticking out the back its up on the left, your have to get the tool in there, but being shaped as it is this isn't much of a problem, although there isn't much cranking space.
    its easy to see once you know where to look, use a torch
    Edit,
    In the pictures on the link above the pictures of the filter are being taken from close to the rear drivers side wheel, so if your looking from there with a torch its easy to see, remember it might be metal or plastic, depending if it has been changed in its life.
    Whilst you have it up on the ramps why not also change the rear diff. oil?
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    I made the mistake of letting too much new oil escape as i tried to get the plug back in, my face got covered lol. I had another go a few days later and did it without losing anything.
    heres another guide just incase The Audi TT Forum :: View topic - Haldex oil and filter change
    Allan
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    433
    Guys both those guides are wrong, its only taken 1 person to put the new oil in through the drain plug and everyone has done it, there is infact another plug to put the oil in, it also ensures you dont over fill the haldex its on the right hand side of the haldex if you are underneath the car facing the rear, you can get a grease gun in ontop of the exhaust, hope this helps.
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Quote Originally Posted by mk1chopper View Post
    Cheers, i had already found that one.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Quote Originally Posted by Jonesy View Post
    Cheers, found that one to. Rather have to much information than not enough..
    Allan
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Great! cheers everyone...
    May 2010
    139
    The other plug that one guy on here is talking about isn't where haldex say to fill the unit from, so don't fill it from there. Pretty sure its a inspection whole only.
    Breezey's Avatar
    Hexxagon Champion
    Mar 2010
    Bridgwater
    433
    I stand correct then, pretty sure its a level plug.
