Chris NottAH Fabrications
Results 1 to 14 of 14
    G60DAN's Avatar
    Cornwall
    318
    HELP Electric Window stopped working
    Hello all
    Well what can I say my passengers side electric window has stopped working and I dont know where 2 start looking can anyone help with this one.
    Thanks for any help
    Daniel
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    Is it just dead ?
    talentwalsh's Avatar
    May 2010
    Galway
    139
    My drivers window decided to give up the ghost a while back. There was def power going through the switch as you could hear the click but no window movement. Took the door card off disconnected the loom from the motor and reconnected it. Window worked again!! The windows work on an automatic electronic breaker and have no fuse to check, I may have just reset it. May be worth a poke before shelling out for a new reg.
    G60DAN's Avatar
    Cornwall
    318
    Think I will power down the car will the window not working show up on vag com
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Have you greased the rails? Sometimes too much resistance cause the motor to think its jammed and wont go back up. Also when its fully down I would check how the bottom 2 clips sits, I had to adjust mine upwards as it was sitting too low on the guide rails and getting bit jammed there.
    gavin89's Avatar
    214
    Quote Originally Posted by G60DAN View Post
    Nope window regulators isnt logged on vagcom, group 46 is not avaliable on our 8Ls. It is only on the newer cars.
    May 2010
    Galway
    139
    I didnt have my VAG COM at the time so I couldnt tell ya, sorry. Ya I considered powering it down too but I said id just check the connections before doing that and it worked. I wanted to check my annoying crackling speaker anyway!
    May 2010
    Galway
    139
    Quote Originally Posted by gavin89 View Post
    Ha, im too slow!!
    G60DAN's Avatar
    Cornwall
    318
    The window is up so that's one good thing will have a look when the wife gets in from work.
    S3PEG's Avatar
    Bristol
    99
    Window regulator clips are prone to perishing... I've recently replaced both of mine.
    Genuine Audi A3 A6 Passat Front Window Regulator Clips on eBay (end time 27-Oct-10 19:28:43 BST)
    There's a guide on here somewhere, I'll see if I can dig it out!
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
    If the door card has been removed the connector can come loose..mine did,also I had to have my motor replaced 150 for the motor.
    Generally the window will go up askew if the clips gone and then the safety mechanism will kick in and the window will go down.
    G60DAN's Avatar
    Cornwall
    318
    Right im getting a ticking noise when I push the button any one
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    probably the motor trying to bring it up.
    my drivers side went and it was the clips that pull the window up on the cables, they're plastic and quite brittle, one broke on mine so the window was only pulling up from one side, this caused it to try and go up skew wiff (new term) and the anti pinch would come in and send it down.
    you need to take the door card out, ther is a screw at the top on the end of the door, and then where your handle is on the inside, the insert in the handle pulls out and there is two screws behind that. these screws hold the door card in place.
    once they're undone, ust lift the whole door card up, its hold on hooks, then the door will be free. you will then need to disconnect plugs for your lights and mirrors, and you should be able to see exactly how it works.
    Yopu'l be able to check the motor is turning and whether the cables are where they should be. If they're ok, i would imagine its the clips. you'l need to remove the silver frame that is bolted to the outer door and has the motor and glass on it, you will then be able to check the clips fully and replace if necessary. they're on ebay real cheap as mentioned above. I managed to just swap mine round, this fixed it somehow. hope you sort it
    G60DAN's Avatar
    Cornwall
    318
    Thanks for that sounds like I need 2 have a good look.
