EM TuningMonster Motorsport
Results 1 to 17 of 17
    scoobyra's Avatar
    It's not f@cking ORANGE!!!!!
    Feb 2008
    Portsmouth
    801
    Effin' pile of shi...........
    After finally managing to start the car today, it was running fairly rough so I decided to run a diagnostic and found a few really odd issues as follows:
    Voltage reading high on cylinder 2 - twice as high as the other three.
    MAF reading all over the place.
    Ok, so, I swapped the coils packs round - still same voltage fault. Changed the MAF, still same erratic readings!!!
    I'm now completely stumped as VAG COM says there are NO FAULTS!!!
    Another interesting thing found - switching between stock map and revo makes bugger all difference so I'm beginning to think that the revo map is causing all the problems!
    JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
    BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
    RGV 250N - Bloody fast and loads of fun........I get wet a lot when it rains....
    Feb 2008
    2,810
    Hope you get it sorted mate. Annoying when car doesn't run right.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    DAylward's Avatar
    Sep 2010
    Portsmouth
    66
    so do you need a lift next weekend then? or do you rekon you can sort it,Sounds to me like the plugs are fecked.Have you ever changed them?
    2003 RS6 Avant,Avus Silver,KWv3 Coilovers,Hotchkiss ARBs,Wagner carbon fibre intercoolers,Milltek cat back,20" C6 RS6 alloys,Kenwood multimedia centre,Unit 20 engine and gearbox remap
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Have a look at your plugs after you have tried to start it, sounds very similar to my issue and mine turned out to be a cracked head
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    your stock map is another version of the Revo software so prob not a fair commentb(as in its Revo's version of stock rather than the proper one)....hope you get it sorted mate
    you prob have done this already....have you checked the wiring going to the coils?
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Earths... as mentioned in your other thread mate, you are having quite a few electrical issues at once it seems... earthing problems can contribute to this... sounds like wiring probs from what you have been saying...
    <tuffty/>
    DJ_Troopa's Avatar
    Back in a turbo!
    Oct 2008
    West London
    1,735
    Visit DJ_Troopa's Instagram Channel
    Take the airbox out and underneath that you will see a black panel which runs from the strut brace and curves under the airbox. If you take the panel strip off you will find a wiring loom in there which runs to the battery. I had problems with mine a while back, i don't know how the wires got bodged but my mechanic was clever enough to re-do the damaged ones and solder them up! Car was perfect after that.
    When this happened my car wouldn't start at all. I had it on vag-com which brought up many faults! Coilpacks 1 2 3 4 high voltage blah blah what you have, N75, MAF, Earth something something etc... Sounds like the same crap i had!
    Inferi Black Cupra K1
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by 1animal1 View Post
    LOL, yeah, those wires can be a true and complete minefield. I know! lol.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    S3 Paul's Avatar
    Oct 2006
    2,759
    The coil pack wiring seems to suffer greatly from heat. they get baked upthere above the turbo.
    I would go checking all the earths too. and the secondary fuse box ontop of the battery too.
    I also had the problems of a plug getting tired... as in the metal inside the plug which is ment to be springy and touch the pins on all the electrical connections around the engine bay had gone loose. So there was a hit and miss signal . There for me was two options... use a very small screw driver to pull these pins back together so they connect tightly when plugged on.
    Noggy Blue 2001 S3
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    801
    Thanks for all the useful advice. If it ever stops raining I'll get outside and have a look.
    One thing I did notice yesterday after changing the spark plugs is that the coil pack plug on number 2 cylinder (the one with the issue) has the little clip broken that keeps it on - maybe it had worked it's way loose and was causing some form of short?? I'll be plugging it back in to VAGCOM again tomorrow so I'll let you know how I get on.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Speaking of earthing... has anyone tried this ??? Waks Wide Web i'm getting a slight hiccup from the engine every now and then when on part throttle and very slowly increasing speed ... if i go full bore it's not there and if i leave it on cruise control it dosn't do it so i'm thinking of doing this as a way of just bolstering up the ignition system... if it was a missfire am i right in thinking vagcom would show it up ?? as it's showing no faults..... also wondering if the MAF maybe due a clean as it's de-meshed and on a K&N filter...
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    DAylward's Avatar
    Sep 2010
    Portsmouth
    66
    so have you found the problem with it yet?
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    801
    Nope! It seems to be running a lot better with the new plugs but we can't work out why the maf is all over the place and cylinder two is twice the voltage of the other three!
    DAylward's Avatar
    Sep 2010
    Portsmouth
    66
    you still going to make it on saturday? or do you want a lift
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    801
    It'll be fine, even with my lowering spring - yep spring!!! Only managed to get one on tonight courtesy of it getting dark too quickly and euro car parts supplying the wrong flipping top mounts!
    Note to self - drive very slowly!
    DAylward's Avatar
    Sep 2010
    Portsmouth
    66
    jeez....you car sounds more and more like something from wacky races
    scoobyra's Avatar
    Feb 2008
    Portsmouth
    801
    We're going to do the other spring and top mount tomorrow night. We weren't actually going to fit the H&Rs but Iain couldn't find his spring clamps and we couldn't refit the old spring as I couldn't get the nut on. Simple solution, fit the shorter H&R spring!! The knocking noise was a shot bearing!!!
