Monster MotorsportChris Nott
Results 1 to 7 of 7
    Apr 2004
    47
    How to replace engine bay lambda sensor?
    Guys,
    How easy is it to replace the lambda sensor in engine bay?
    do i need to get a garage to replace it?
    thanks
    ravi
    Apr 2004
    47
    sorry, i have a S3, year 2000, apy engine.
    cheers
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    It's fairly easy to do, i found it a lot easier using a lambda socket > Draper Expert 22Mm 3/8" Square Drive Lambda Sensor Socket: Amazon.co.uk: DIY & Tools
    Apr 2004
    47
    thanks, do i need to remove any engine parts to get to it?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I had to remove the strut brace but i don't think the APY's had one. You could remove the chargepipe to make things easier but it can be done with it staying on
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    I removed the inter-cooler inlet hose that runs along the top of the engine and this made it easy to access the lambda sensor. As sandip points out - proper tools always make the job easier, especially when access is limited as you will find out. It's a 30 minute job with a cold engine and proper tools. I spent a good hour on this as I neither had a proper tool to reach the lambda or the time to wait for engine to cool down
    Apr 2004
    47
    thanks guys
