Chris NottJMB Retrofits
Results 1 to 17 of 17
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Temp guage slow to rise / not at all
    Hey all..
    Temp guage dosent seem to be working properly, its sort of all or nothing.
    Sometimes itll warm up to 90, although taking over 20 mins, then will drop to 0 again?
    Common fault / easy fix?
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Sounds like your thermostat has broken, not a hard or expensive job to replace. Do a search on it should return a few threads where people have replaced them. If its not the thermostat its more than likely the temp sender, also easy to replace.
    Feb 2009
    Telford
    31
    i had the same symtoms as you've described, i replaced the temp sender and now the thermostat stays at 90 or just below
    didn't take 5 mins to replace
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Yeah id try the temp sender first as its a dame site easier to change than the stat
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    If your going to change your temp sender, make sure to do it when the engine is cold. Also, try and get a new o-ring for it too when purchasing the sender. Open the cap on the expansion tank to relieve any pressure in the coolant system and close it again. Temp sender is located at the right side of the head, held in by a black plastic 'horse-shoe' clip.
    Pull out this horse-shoe clip and lift out sender - make sure the o-ring is also removed at this stage (it tends to stay on the platic flange and you'll wonder why the new sender with its new o-ring dont fit!). By keeping the cap on the expansion tank, it creates an airlocks of sorts and stops all the coolant gushing out, this method will let it loose about a tablespoons worth. HTH,
    Imteyaz.
    TimG's Avatar
    Feb 2004
    South Coast
    932
    I have the needle not reaching 90 degree problem. In traffic it hits 90, but on the move it barely makes 70, I assume as the thermostat is stuck open and the radiator is cooling the car down when moving. I changed the temp sender as its the easy first option, but it didnt sort it, and now have a thermostat to go in at the weekend! Hope it will sort it out.
    Not too sure what damage will occur by leaving it too long, I guess just some fuel economy drop as the car is 'cold' all of the time unless stationary! Not noticed a severe lack in economy though TBH.
    Jun 2010
    Just north of Durham
    32
    3-5mpg is normally the difference with a faulty sensor
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    ^ correct you will get over -fueling of some sort they should ALWAYS stay at 90 under or over you have a problem
    S3KO4's Avatar
    Aug 2009
    London
    850
    I would put my money on the thermostat. its probably sticking open a bit. if the sender was at fault it will make no difference to the reading if the car was moving or not.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Thermostat for sure.
    Audiless
    Bingley
    875
    Cheers guys, ordered a thermostat friday 23 which dosent kill the bank either
    Dazboss's Avatar
    Like A Thristy Dingo ;)
    Jul 2010
    366
    Im just about to change my stat today. Make sure you have a jiggle pin on it if not drill a small 6mm hole in it
    Audi A3 Quattro Sport 180bhp
    Pic's comimng soon !
    Dazboss's Avatar
    Jul 2010
    366
    Mine was taking a long time to warm up / show up warm. Just done the stat its not nice job. The bottom bolt is a joke, ze Germans must of been on the pop when they slapped the bolt holes in.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Stealerships charge around 16 for the new 'green' sender - there are two different shaped senders, make sure they supply the right one as I'm led to believe that the early cars had different shaped ones - not sure what year your car is but the later ones are "church window" shaped (technical term from the stealership I got mine .
    Clicky me: VWVortex.com - DIY: Replacing your temperature sender with the updated one (green-top)
    Imteyaz.
    Jun 2007
    624
    Quote Originally Posted by scott_johnson View Post
    Thermostat here is 8.05 Audi - Euro Car Parts UK
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Scott,thats really expensve for a stat,can get them for bout a fiver mate.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    My money is on the stat also. If you see the needle rise to 90 in traffic when there is no airflow through the rad, then the sensor is clearly working as it is getting a reading.
    No dash activity, or erratic dash activity normally mean the CTS.
    Homer Simpson
