Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    scott_johnson's Avatar
    Audiless
    Bingley
    875
    Checking Power Steering Fluid level!! Help needed asap!
    Hey all. Probs a silly question but to check the level, do you have to screw it all the way in, then out and check it, or do you screw it out, wipe it and just dip it in the top?
    If so, screwing in looks like its over full and just dipping it in looks like it needs topping up!! lol.
    SJ
    S3 Paul's Avatar
    Oct 2006
    2,764
    Screw it out. wipe it... screw it all the way in then back out to check it.
    Noggy Blue 2001 S3
    Ross_S4
    Aug 2009
    Dundee
    718
    As Paul said, remove, wiipe, screw in, remove and check.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Where is it based?
    S3 Paul's Avatar
    Oct 2006
    2,764
    where is what based???
    the power steering res.?
    Noggy Blue 2001 S3
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    under the cover on the left hand side looking at the engine from the front
    S3 Paul's Avatar
    Oct 2006
    2,764
    if i remember right... it has a green top.
    Colour coded to the fluid so im told????
    The top looks like it needs a big arse flat blade screw driver to undo it
    Noggy Blue 2001 S3
    Ross_S4
    Aug 2009
    Dundee
    718
    or a 2p coin, or the blade of your key. it shouldn't be gorilla arms tight anyway.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Thought it was that, cheers boys, never checked it. What fluid does it take? Think mine is probly due a change.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,057
    Make sure you use the genuine stuff,it only costs about 8 from dealers mate
    Audiless
    Bingley
    875
    Cheers guys!! My steering feels heavy thats all and i was hoping the fluid was low so itd be a case of topping it up. Would it have adverse effects if it was too full?
