Volks AutosSky Insurance
Results 1 to 12 of 12
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    need help asap! about my lowered a3
    my a3 is lowred on coilovers and the driveshaft has broke 2 times now! the gearbox still spins but it aint spinning the actuall shaaft, could this do with the car being to low? havent got a whiteline arb ordroplinks.think its only lowered 45 - 50. geting fed up with this now!!! any help be appreciated, thank u
    CAR IS GONNA BE LOOKING SWEEEET :D
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    its too low mate. i had to get eibach arbs to clear it properly. now i have no problems with even 4 ppl in the car. raise it until u can get a new arb
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Alex C's Avatar
    Lizard, Cornwall
    2,600
    Quote Originally Posted by audi-tk View Post
    ah
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    would you say its that causing the problem? drivehsaft ,all the bearing at the end of the driveshaft where ti goes into the gearbox have all grinded away.not even balls any more lol
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Hehe "Boy racer" springs to mind in this case...
    The whole lowering topic has been covered time & time again & some folks never learn... I did, years ago & learned the hard way...
    If you're going to lower a car, do it right & dont just chuck on a set of springs..
    Oh & I have a set of standard S3 ARB's which might help
    ...... Now this one's MUCH better!...
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    ive got coil overs mate
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    I had a Little ARB against driveshaft rubbing. Was worried of a broken driveshaft so removed the arb altogether! I know people on here will look down on this, but there is no noticable difference in the handling without it. And as long as you remove all remnants of the arb including the droplinks you shouldn't have any MOT issues either. Many GTis are running without ARBs over on E38. I just used an angle grinder to cut the ARB near the bend near the subframe, removed the droplinks and bushes and pulled the ARB out. Job done! No more issues...
    May fit a whiteline ARB once they're back in stock
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    will look into that.but be better to get the tt arbs ? cheers
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    stop making random guesses at things!
    Do it properly, or raise it back up.
    To fit a TT anti roll bar you'll need TT/S3 front struts, as the ARB mounts to the coilover body and not the wishbone. this if effort that you don't need to go to.
    Buy an uprated anti roll bar with larger hoops and your problem will be solved.
    Don't just remove the ARB totally, that's fine if you just want the looks, but it's a bad idea for the handling.
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Agreed. If you do remove the anti roll bar do not gun the car around corners. I have done this for the looks and being a 1.6 do not drive the car too spritedly.
    Wanted to eradicate the rubbing issue before the whitelines are back in stock without having to wind the coilies up.
    Although on a sidenote, my theory is if you remove the ARB and wind the coilies down the car's centre of g is significantly lower which should reduce the instability of removing the ARB.
    gavin89's Avatar
    Wana go Low gotta go Slow
    Bournemouth/Manchester
    214
    Quote Originally Posted by bhavin1986 View Post
    Erm maybe to a certain extent, but I don't agree. The purpose of the ARB is to reduce body roll, even if your centre of g is low, it doesn't fully counteract the compression of the suspension when your car goes around a bend. With an ARB fitted, the lower part of the suspension movement relative to the car chassis is transfered onto the same component on the other side, so the twist torque of the anti-roll bar always tries to fight against the compression, therefore reducing roll. Also on situations where both of your wheels aren't level, i.e one wheel is riding on a hump, the anti-roll bar will be twisted and transfer the force to another wheel to push it down, so the car body will remain balanced. Without ARB, you wont get any of those benefits...So i recommend you still fitting one
    audi-tk's Avatar
    Aug 2010
    bedfordshire
    444
    yeh ill stick to keep mine or buy an uprated one lol. try and find a second hand one if any1 is selling any cheers for help peeps
