Volks AutosBadger5
Results 1 to 12 of 12
    May 2010
    Staines Middlesex
    131
    cheap turbo upgrade or not?
    have been looking at this just wondering wether its a good idea or not?
    T28/T25 Turbo Charger | Turbos | Turbo and Boost Kits | Turborevs Ltd
    i brought a fmic from them and it seems good enough.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    I hope you aren't assuming its a bolt on upgrade as its not...... I would avoid tbh...
    <tuffty/>
    May 2010
    Staines Middlesex
    131
    what extras would i need? as they do the turbo on its own for 325 as ive already got DV etc.
    RIP S3dave
    May 2004
    nr Glos
    7,175
    its T25 flanged, yours is 3 bolt Borg Warner flanged... so new exhaust manifold
    Its different outlet, 5 bolt, so new downpipe also req'd
    new TIP required
    larger injectors req'd
    large maf required
    etc etc etc
    and for that money its not a garrett turbo, more like a chinese copy with the potential reliability question that brings
    A3 or S3?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    Exhaust manifold, downpipe, maybe injectors, mods to the charge pipe, mods to the intake, stage 3 map... maybe rods... doesn't look water cooled from the description which is a downgrade in my book and if its roller bearing rather than journal bearing then you would need a oil restricter if there isn't one supplied with the kit as the std turbo uses a high pressure oil feed whereas ball bearing turbos don't... then you would prob need custom oil feed pipe and to mod the oil drain depending on what manifold you went for...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    ... beat me to it Bill
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,175
    its hardly a bolt on is it.. lol
    www.badger5.biz
    bill@badger5.co.uk
    May 2010
    Staines Middlesex
    131
    ive got an A3 1.8TQ its been stage 2'd but im really bored of it lol. was looking at either a mini cooper S or upgrade the car a bit more. what kind of price would i be looking at to have a garrett fitted?
    spoke to JBS autodesigns and they told me 3500 fitted! which in my opinion sounded a hell of alot!
    also ive heard the 1.8TQ's came with a K03S turbo? i fitted a forge intake pipe and i am pretty sure when fitting it i have a K03!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    3,500 sounds cheap to me
    <tuffty/>
    May 2010
    Staines Middlesex
    131
    CHEAP! better off going for another car! does the K04 make alot of difference? and what kind of price would i be looking at?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,573
    There is a K03 hybrid (uses K04 internals) which is a better option as it fits onto your existing manifold and downpipe, you will need S3 injectors, S3 MAF, silicon TIP with adaptors for the S3 MAF, cone filter for the S3 MAF and stage 3 mapping... still looking at over 2k for that lot plus fitting...
    Also recommended you do the rods too if you want to run higher boost...
    You could also try and source the K04 and required parts from someone doing a BT conversion or from ebay but you will still need stage 3 mapping...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,175
    Quote Originally Posted by tyson View Post
    for a real high 200's, and slightly more than an S3 will do, a K03/4 hybrid will be lower cost for you.
    Welcome to CRTurbos do these on exchange.
    supporting mods being silicon tip, 370cc injectors, 3" downpipe, induction, fmic.. and of course a map to suit
    on ibiza's these make 260-275bhp on my dyno, where S3's make 260bhp max (so far on stock k04)
    www.badger5.biz
    bill@badger5.co.uk
