Hi
I got a 2001 stock S3 - owned it from new and in 120k not a single engine component failed (xcept coil packs - all changed 20k ago) on it until a few weeks ago when it had to go in for a head gasket change -Rude awakening there!
Anyway, since then the car aint right -Under hard acceleration, it hesitates around 5k rpm in 4th/ 5th and the amber engine light flashes for a bit until I back off. I'm getting these codes from VAG com...
Control Module Part Number: 8N0 906 018 J
Component and/or Version: 1.8L R4/5VT 0004
Software Coding: 10710
Work Shop Code: WSC 06435
Additional Info: WAUZZZ8LZ1A056408 AUZ7Z0Y1650315
4 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 35-10 - - - Intermittent
16487 - MAF sensor(G70): signal too high P0103 - 35-10
16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10
16685 - Cylinder 1 Misfire Detected P0301 - 35-10 - - - Intermittent
anyone got any ideas? After the big spend on the head job I gotta dig these out for myself...
Thanks guys....
4 Faults Found:
Thanks guys....
