ex_scoobydoo
hi
i have noticed a strange problem in low revs, example: when pulling away from junctions slow the car seems to get to around 2-30000 revs then it has symptoms as if its running out of fuel, it sort of hesitates, like a slight judder until i change up a gear then, it will do this through to third, after that its fine, sometimes in 4th 5th if i hold the accelerator in the same position i get a slight flutter. if i power through the gears from a stand still, no problem, its nice and smooth, i notice this is intermittent, it wont happen all the time, and it makes no differance if the car is warm or cold. i have checked all breather pipes and their is no signs of splits, and last week it was on a snap on diagnostic machine and came back with no apparent faults.
can anyone shed any light or have had the same sort of thing.
thanks
thanks
