Chris NottSky Insurance
    Sep 2010
    wirral
    468
    Difference Between K04's ??
    hi there just been speaking to an Audi specialist regarding my turbo .. apparently mine is a k04-020 and from my research i know there's a k04-022 and k04-023 available ...
    will either of these fit onto my car ? its a 1999 s3 .. as i have found a k04-023 for Ł200 just had seals done with new feeds on ..
    cheers
    It's all in bits
    Apr 2006
    Bristol
    219
    K04-023 has a hole for an egt sensor which the early S3's don't have. I would assume you could blank this if you wanted though.
    Sep 2010
    wirral
    468
    Hmmm not sure haha don't want to fork out and find out can't use it .. So turbos are all the same ?
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    the K04-001 is different, but the turbo is pretty much identical with regard to the 022 and the 023 IIRC. Just the EGT probe.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Sep 2010
    wirral
    468
    Ordered a k04-023 as aparently the difference with that to the k04-020 is just an exhaust temp gauge which can be blanked off and a bargin at Ł180 :-) just had seals done too ;-)
