Sky InsuranceJMB Retrofits
    Oct 2009
    86
    A3 20vt quattro smoky idle
    Hi guys i have a a3 running revo stage 2.5 and have recently fitted a decat pipe and since doing this it smokes quite bad on idle not blue smoke/oil just smells normal. any ideas wat can be causing this thanks
    13.8 santapod gti fest 2010 class g 1st place winner. A3 1.8 20vt 180 quattro, Revo stage 2.5 map,[/B] Forge tip, forge cold side, Forge splitter valve, Carbonio cold intake with aem filter,decat pipe, 2.5inch exhaust, k03s turbo with forge actuator, revs fmc with forge houses, j n75 valve, 4 bar fuel reg, hid's, 17" tt alloys t1r
    S3 Paul's Avatar
    Oct 2006
    2,764
    Did you have the post cat lambda sensor turned off?
    If you didnt that may be the problem. Failing that i would get the car logged and checked with vag com.
    A cat will hide a few things... worn engine parts being one of them.
    Noggy Blue 2001 S3
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Are you sure it's smoke and not just condensation? Bear in mind you have no cat in there now - extra condensation is common.
    Homer Simpson
    RIP S3dave
    May 2004
    nr Glos
    7,191
    turbo... tired.. and or exhaust valve guides/stem seals
    change of backpressure on the seals without cat now can it seems draw oil out
    how oiley are your charge pipes?
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Oct 2009
    86
    Charge pipes have small amounts of oil, turbo was rebuild only 12k ago but it does have a hard life so maybe it time for second rebuild, or hybrid time :-) if it still smokes be stem seals I guess, thanks for replys.
