Hi, i've just finished bleeding my brakes using the Gunson EeziBleed kit. Everything went well used about 1 and a half litres of dot 4 fluid. I did the nipples in correct order and was surprised by the amount of dirt and bubbles coming out. Anyway, thought id test it quickly down my road and brake pedal has gone worse. It feels very spongy and unresponsive, they work, but you end up putting the pedal all the way down!
Do I need to run Vagcom following these instructions?
Ross-Tech: VAG-COM: ABS Brake Pump Bleeding
any other ideas, as far as i'm aware i've done everything right! Oh also when i finished the reservoir was to the brim, i got a little out but have a feeling its overfilled, would this make a difference?
Allan
Allan
