AH FabricationsVolks Autos
    mephisto's Avatar
    Oct 2004
    190
    Removing OS headlight on S3 (advice req\'d)
    I need to fit a new indicator cluster on OSF. How do i removed the headlight assem? I tok the top 2 Torx screws out, and the whole thing is pivoting somehwere?! Help, i don't really wanna start yanking!
    cheers,
    M
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Removing OS headlight on S3 (advice req\'d)
    is it a facelift or old style? The oldstyle you dont need to take the headlight out to change the indicator. If it is the facelift and you do need to take the whole light out then you will need to remove the front bumper to get at the last bit that is is rotating on.
    mephisto's Avatar
    Oct 2004
    190
    It's the old style (2000 June)..ooh does it just pop out?
    mephisto's Avatar
    Oct 2004
    190
    Ahh i see now, just need to lift the plastic lip holding the end of the assembly on (near holding screw) If anyone else struggles like i did ooops. As when i first undid that screw nothing seemed to give.
    Anyway thanks for the guidamce.
