Results 1 to 15 of 15
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    DIYT fitting rear shocks and springs, 2002 S3
    Presume this is just as easy as when I did it on my old Clio? Bolt at the top, bolt at the bottom for the shocks and springs basically fall out of the rubber mounts when the shocks aren't attached?
    Is it worth replacing anything else while I have the back end of the car up (shock mounts/spring seats) etc?
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    if sticking with standard ride hight then thats it! if lowering then lower tie arms are always advised
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    From memory the spring still requires clamps to be used, although I was only replacing the spring so cant remember if I removed the bottom bolt of the damper to drop the wishbone. I might have just jacked the car up removed the wheel and clamped the spring to remove it then recalmed the new spring to install it
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    ive heard you can lever the ?trailing arm? down and remove the spring without compressing it
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by Speedy Steve View Post
    Just OEM parts fella, so yes.
    Quote Originally Posted by mk1chopper View Post
    Cheers buddy, that about answers it from the above.
    Any ideas on the bolt sizing? Not urgent, but be useful!
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by Cookstein View Post
    Precisely what we did with the Clio...
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    vag cat shows it being an M14 bolt, going by this conversion chart its 21mm or 22mm socket required I think Metric Nut, Bolt, Screw, Washer Threads, Dimensions, Sizes, Tap Drill Size, Hole Size,
    I dont think you can get away with levering down the trailing arm on the S3 due to the wishbone (4 wheel drive remember) I think i did remove the bottom bolt to fit the spring, once I fitted the new spring I think I used a car jack to push the wishbone back up to line up with the damper to refit the bolt.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    See what the price of spring mounts/caps are if there not much its probably worth replacing, although I dont think I bothered although I was only replacing the one spring that had snapped. upper base 1J0512149H lower stop 1J0511155D lower washer 1J0511341A, these were for a 2000 reg, if you use www.vagcat.com you can check for your year
    JD09's Avatar
    Dec 2009
    3,080
    Appreciate both replies guys and the links. Should be easy but can never have too much info on something new to me!
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Easy as pie, rear spring doesn't need compressing, a good bit of old fashioned he-man power will pull it out.
    JD09's Avatar
    Dec 2009
    3,080
    How about utilising the fact that it's in bits
    Christer's Avatar
    Engage the beige!
    Oct 2009
    Oslo/Trondheim, Norway
    254
    This guide explains it really well!
    Noah's MkIV VW H&R Coilover Installation HOWTO
    If you're fitting original springs, you might need som clamps.
    2005 Audi A3 Sportback 2.0TDI in Dakar Beige
    FK Coilovers, 19" BBS Speedline (Summer Wheels), 18" BBS CK Replicas (Winter Wheels)
    Ross_S4
    Aug 2009
    Dundee
    718
    JD09 -
    On your nearside rear lower track arm you will have a headlight level sensor clamped onto it.
    It is important you disconnect this BEFORE dropping off your damper else you will break the plastic arm on the sensor.
    There is a ball joint each end of the sensor linkage u can split, or unbolt the bracket from the lower arm, either way is fine.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    good shout ^^^^
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by rossbrownlee
    JD09 -
    Really appreciate this buddy, I know about it but hadn't thought about it!
