Badger5Chris Nott
    Aug 2008
    114
    Steering noise??
    When reversing out my drive, I have a wining noise from slight steering.
    Any ideas? Car is also lowered on coilovers
    Aug 2008
    114
    Also I have checked the power steering level and seems ok
    Aug 2008
    114
    anyone??
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Only in reverse? Never does it in forward drive?
    Homer Simpson
    Aug 2008
    114
    no it does in forward aswell only when goin slow? cheers for the reply
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Sounds like a PAS issue. I would start with bleeding the PAS system, however I would expect it to be the PAS pump.
    Worth bleeding it just in case though - however it would normally bleed itself under use.
    Jack both front wheels up off the floor. Take the PAS res cap off. Check the fluid before hand.
    Turn the wheels from full lock to full lock about 10 times, and check for bubbles in the PAS reservoir.
    Shouldn't take more than half an hour at the VERY most - so worth a go.
    If not, I;d be looking at the PAS pump.
    Homer Simpson
