Chris NottBadger5
Page 30 of 36 FirstFirst ... 202324252627282930313233343536 LastLast
Results 1,161 to 1,200 of 1409
Like Tree11Likes
Thread: Another hybrid conversion thread....
  1. #1161
    RobbieRolex's Avatar
    Oct 2010
    Ireland
    82
    If you run out, just fire anything in there, bottled water from the shop, it will help.Also motorway driving is where i use the least amount of meth as i am not on boost the whole time.Farting around town on low gear's/high boost is where i use the most, and logging, you will pi$$ through the stuff when logging.I buy it in 25l drums.
    I have only gone thru 1 x 25l drum since i set it up a few months back, everyone is different, if you are on boost the whole time you will fly thru the stuff.
    Mk1 Cupra R Hybrid with goodies @ 318bhp & 314lb/ft and only 2WD
  3. #1162
    Oct 2010
    Ireland
    82
    Hi Bill, i spied a few bottle of the industry stuff over here that uses Methanol and yes i had an incident with this stuff also, ( well, diliberate incident, LOL) so be careful, use gloves in a well ventilated place and dont get it in your eyes or smoke near it.If you have to have it at your residence make sure its away from the house if poss or in a locked container, its nasty ass stuff.
  4. #1163
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    firestarter, twisted firestarter!
    So, your christmas present this year Bill is:
    Homer Simpson
  5. #1164
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by RobbieRolex View Post
    Is it good for flow testing manifolds....?
    Homer Simpson
  6. #1165
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    That pretty much describes me to a T. Bugger.
    Homer Simpson
  7. #1166
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    if its mapped to run with it will it sh*t itself when it runs out?
  8. #1167
    Oct 2010
    Ireland
    82
    It depends on how much advanced timing you have dialled in for the WMI, i turned mine off the other day while logging and she started pulling 9* of timing retard, timing retard of over 10* and you should be worried, this can be a factor in engine destruction and should be avoided according to the TT tweakers guide.
    If you run out the engine will run fine as long as you avoid WOT and just generally avoid giving her a thrashing until you top up.If you can't top up with Menthanol/water you can still use water to cool you will just be missing the octane(stablisation) to the fuel the methanol offers.
  9. #1168
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hmmmm, like you said, if you stay off the boost then all should be well. Not ideal though, I still think a spare few litres in the boot would be a good idea.
    Homer Simpson
  10. #1169
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Found a methanol supplier.
    He is able to deliver me 50 litres of virgin grade meth for Ł60 all in, including containers.
    What prices are everyone else paying?
    Homer Simpson
  11. #1170
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Personally, i'd map the engine WITHOUT the meth.
    Adding the meth on top without tweaking the map will still give you more power and reduce temps etc, but then should you run out your not going to blow it up, as the map is safe to run without it.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
  12. #1171
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Half of me agrees with you, the other half doesn't.
    I agree with the fact that you build in safety and reliability without dialling in extra timing. The higher octane fuel and the cooling effect of the water will make a difference anyway.
    BUT
    The additional timing advance possible is a real tempter. 4 degrees at the minimum advance is realistic, and in my eyes is partially the point of a WMI install.
    Hmmmmm.
    Homer Simpson
  13. #1172
    "Stick a V8 in it!"
    15,372
    I just dont think its worth the risk.
    Your pump could fail, fuse could blow, wires/pipes could come off etc.
    Plenty folk running WMI on S4's and RS4's that are tuned to the moon, and the general consensus over there is you map the engine without it, then add the WMI later to gain some power and add a bigger safety margin.
  14. #1173
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I'll take that on board, because I do completely see your point. It is a risky business....
    Homer Simpson
  15. #1174
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Crank it up to 11 Welly.
    You know how much you love taking that engine out and rebuilding it anyway...
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
  16. #1175
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by JS1500 View Post
    Hmmmmm. That would be some good timing advance!! lol. 11 degrees should see getting on for 30bhp gain.
    Homer Simpson
  17. #1176
    JS1500's Avatar
    Howdy
    Sep 2009
    1,167
    Do it!
    Then when something goes pop you've got a great excuse for the 3.2T conversion...
  18. #1177
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Do it!
    I swear sometimes you people are my worst enemy.... lol.
    Homer Simpson
  19. #1178
    Oct 2010
    Ireland
    82
    I put on an additional 12* up top when testing the WMI, i wouldn't recommend this for everyday use and it should be noted that you don't want to add timing across the range with the likes of lemmiwinks moreover the timing should be added up top where you are using the WMI, Bill can do this.
  20. #1179
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    You might be happy with gains you get from no extra timing, and it will be safer. Win win.
  21. #1180
    Oct 2010
    Ireland
    82
    Boring .
  22. #1181
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    Haha. Suppose you gotta push the boundaries eh
  23. #1182
    RIP S3dave
    May 2004
    nr Glos
    7,175
    wmi and timing advance is a choice.. as is what wmi % you mix
    folks can decide whats right for them
    the majority I see however are running additional ign to go with the wmi, and running full on 50-50 mix for all of the gains.. but keeping an eye on things also.
    You can buy kits which will drop out the boost when the wmi's run out, so you can make a safe system. Its a little more costly of course but its an option for those who worry about forgetting about the tank level.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  24. #1183
    Oct 2010
    Ireland
    82
    True Bill, its definetly not a mod you can install and forget about, along with topping up, it needs maintenance. However most kits have a level sensor that can inform you in car if you are running low.I used the sensor from my washer bottle, you could hear that think beep from outside the car, many a time it scared the ****e out of me when driving hard. I am keeping my eye out for a long thin reservoir that i can mount along the crash bar or something, 15L+ it would help me get more weight on my poor little 2fwd.
  25. #1184
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hmmmmm - update - see this:
    XS Power K04 Manifold for 210/225 S3
    Homer Simpson
  26. #1185
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
  27. #1186
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Awesome news mate
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
  28. #1187
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Well, I've spent some dosh today....
    Bought a cooling mist WMI kit - mainly for the pump and pipework etc. 150 psi pump and it also comes with a tank which I won't be using. Ł100 delivered.
    Also bought a Golf MK4 V6 4Motion subframe. Well, not just the subframe, also comes with the ARB, drop links, wishbones and steering rack with track rods and ends. Ł65 collected from Solihull. Bargain!
    Hopefully the sub frame, combined with new bolts & rack mount bushes will solve my 'Phantom Clunk', and the WMI kit gives me all the stuff I need to get on and fit WMI.
    That combined with a potential manifold makes this a good week....
    Homer Simpson
  29. #1188
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Great Welly get the spanners out, particulary interested in the WMI install
  30. #1189
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    You can flog that steering rack for about a hundred to the mk4 golf guys - they are always after those. Bargain m8!
    '01 AMK, completely standard except for the Ambient Lighting Pack.
  31. #1190
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by SiGainey View Post
    Yarp
    Homer Simpson
  32. #1191
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    OK, binned the EVAP system tonight.
    Easy enough job to do to be fair. I will post up pics tomorrow when I can get some in the light to demonstrate how/what/where it's done.
    Has made an ideal space for my WMI pump to live - really pleased...
    Homer Simpson
  33. #1192
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    So - pics:
    Planned place:
    Post removal of EVAP.
    Nice and close to the screenwash tank (which I plan to use as the Water Meth tank) meaning no long pipe runs. It will also be nicely protected from the elements living there.
    Just waiting for the pump etc to arrive so I can mock up sizes and make a bracket to fit. The threaded holes from the Carbon Canister will be most useful for that me thinks...
    Homer Simpson
  34. #1193
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    Nice one dude, you've got your engine cover on! are you feeling alright?
  35. #1194
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    where did you get your oil filler cap??? thats a nice little touch
  36. #1195
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Dane View Post
    I do try and keep it on these days after the amount of abuse I got up at ADI and Audis In The Park.... lol.
    Homer Simpson
  37. #1196
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    My missus's parents bought it for me for Christmas - which was really appreciated actually...
    Ebay here: Oil Cap for A2 A3 A4 A6 Q7 RS2 RS4 RS6 S2 S3 S4 S6 TT on eBay (end time 28-Jan-11 04:15:45 GMT)
    Available in about a million colours, and really well made to be fair. It's turned from a billet.
    Homer Simpson
  38. #1197
    Dane's Avatar
    Cheltenham
    4,003
    haha! The 'screws' that hold mine down have gone walk abouts so I may be feeling that rath this year
  39. #1198
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Welly, any benefits to removing the evap system?
  40. #1199
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not performance wise, no to be fair. I didn't think there would be any, I did it solely to make better use of space.
    On the other hand, you do get rid of a bloody ugly stupid canister.... Also obviously, IMO, getting rid of pipework can only be a good thing.
    The solenoid seems to have stopped click as well which is a bonus, as that used to drive me mental.
    Will monitor MPG over the coming weeks, as I suspect that if anything, that's what it will affect.
    Be warned people with AMK engines or BAMs doing this that you should expect to see an 'EVAP System incorrect flow detected' fault code, even if you leave the solenoid plugged in.
    Homer Simpson
  41. #1200
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,570
    ...Be warned people with AMK engines or BAMs doing this that you should expect to see an 'EVAP System incorrect flow detected' fault code, even if you leave the solenoid plugged in.
    Yarp...
    <tuffty/>
Tags for this Thread
