JMB RetrofitsVolks Autos
Results 1 to 8 of 8
    MUSH's Avatar
    MUSH Developments Ltd.
    Jun 2010
    Newcastle
    712
    S3 engine removal
    hi guys,
    im about to pull the lump out of my 2000 S3 APY as its knackered. In its place will be a 1.9 GT30 powered lump. However having only played with mostly mk2 golfs and once breaking a Leon Cupra im lacking in experience (however an abundance of enthusiasm!!) with regards to engine removal on these newer breed motors. However im quite conversant with 20v lumps having played with them in my old mk2 golf.
    I am assuming the front end comes off to enable me to perhaps wheel the lump out? Or does it come out from the top with an engine crane?
    Ive read the audi-tech on dropping it from the bottom but that is no good for me as even though ive got a decent little workshop with jacks/stands/crane/tools, a ramp is one thing i dont have!
    Any hints/tips/advice will be appreciated. This isnt happening til i get back from my hols in a few weeks but im just gathering info so im ready.
    cheers
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,460
    If your planning on removing the the gearbox as well then you could take the slam panel off and take it out the front
    I was limited on space when i took my engine out so i removed the head to give me more room, then dropped it out the bottom with the gearbox on its mount
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Ill probably just take the box out aswell as a new clutch and flywheel will be fitted aswell as a new gearbox end mount and fresh oil so itll probably be easier to do it all in a oner. plus it will be a built up long block that will be going in so splitting in the removal stage will make up no time for later on during the refit.
    its good to know it will fit out of the front though. Ive got it in my double garage so space isnt that limited for removal and storage afterwards.
    cheers for your reply bud
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Just as easy as a MK2. The front comes off. Also you don't have the rear engine mount like the Mk2. It just looks hassle because of all the gaff around the thing.
    But you'll have to re-gas the AC.
    Apr 2010
    61
    S3 engine removal
    It's very simular to a LC, what happened to your old engine?
    And what are do doing with it? If it's rebuildable?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Andrew@A.L.D View Post
    I did it in exactly the same way - and then reassembled in the reverse order back in the car.
    Homer Simpson
    MUSH's Avatar
    Jun 2010
    Newcastle
    712
    Yep i knew id have to regas the aircon, but thats nowt really, one of them jobs for when its back on the road!
    Reckon the frontal removal will be used here. If it is pretty much the same as the LC then ill be fine. The reason i cant build it back up when its in is because the replacement lump is already built (JNL racing 1.9).
    As for whats wrong with the lump, it was written off by perth audi due to oil pump failure. Hence i bought it at a bit of a bargain price.
    71k miles and fsh...
    current poorly engine...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Sweet - good work
    Homer Simpson
