Chris NottSky Insurance
Results 1 to 15 of 15
    Jul 2010
    Fife
    20
    gearbox oil (will this be ok?)
    i have a 1.8T A3, 1997, 125k, and looking to change the gearbox oil, will this be ok to use?
    Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic manual transmission fluid
    i drive enthusiastically most of the time lol,
    cheers
    matt.
    Sep 2009
    Mid Sussex
    162
    Sorry I can't answer your question, but I always go to 'TPS' and get the original Audi gearbox oil. It's not expensive.
    A3 1.8t quattro -
    THS high flow manifold, S3 milltek, Forge 007 DV, THS engine mounts, Performance Haldex Controller (blue), Panel filter
    Coming soon - FMIC, Hybrid K03 Turbo, Custom downpipe & high flow cat
    Sep 2009
    Essex
    2,366
    same here. easier life. just get what vag put in there because VAG are not particularly open about the spec of fluid that goes in there
    Jul 2010
    Fife
    20
    ok cool, thanks, its just what opie recommend,
    oh and my local audi dealer is 40 miles away, could i get it from a vw garage?????
    Sep 2009
    Essex
    2,366
    yes. theyre the same car!
    Jul 2010
    Fife
    20
    great the vw garage is 5 mins down the road so that will save me a bit of time and money lol.
    cheers guys
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    doing my gearbox oil next time i have a chance to get out there.
    I'm putting this stuff in.
    Motul Gear 300 75W-90 Racing gearbox oil.
    Motul GEAR 300 75W-90 Racing gearbox and differential lubricant 100% Synthetic
    a few people on here said its good stuff
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
    Sep 2009
    Essex
    2,366
    fantastic... when you gonna be racing it?
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    621
    Every time I drive it. Lol
    Na next year when we go to the ring.
    fran-s3's Avatar
    1,090
    Is it a hard procedure to replace the gearbox oil? How much on average would a specialist charge? (thinking of doing this next service if it's not a massive job)
    Sep 2009
    Mid Sussex
    162
    Very easy,
    Jack car up (level)
    Remove filler/level plug first (just encase you can't get it undone before you drain the oil)
    Undo drain plug, and drain oil. Put plug back in or run some new oil through first, then re-fit plug.
    Two ways to refill use a pump or pump bottle from low level, or do what I did. Use a hose and funnel above the engine bay and route the hose into the filler plug and re-fill.
    If you have a 6 speed box buy 3 litres you may not need it all.
    You know when it is full because it comes out the filler/level plug. Do filler plug back up.
    A3 1.8t quattro -
    Jul 2010
    Fife
    20
    bought all my oils and away to change both engine and gearbox oil today, new strut top mounts, new denso spark plugs, new fuel filter..... just wish my lowering springs had arrived yesterday....!!!
    busy busy day, just hope it doesnt rain AGAIN!!!!!!! lol
    F*ckin scotland for you... lol
    Apr 2010
    Hi, i think i may have been lied to my local mechanic, just booked my 1999 18.T in for an oil, filter and strainer change asked about the gearbox oil an he said its a sealed unit cant be changed. Its done 94K
    May 2010
    139
    Quote Originally Posted by jackera View Post
    It can be done very easily, would take a mechanic minutes to do. Although it would be alot easier for you to do, the mechanic doesn't fill me with hope.
    Sep 2009
    Mid Sussex
    162
    If you saw the crap that comes out, you would defiantly want the oil changed, I don't care what people say it does need changing. Oil still degrades....
    A3 1.8t quattro -
