I have always said the exhaust system on a S3 is'nt great and you can get a very good gain from a larger + better flowing system. How loud is it now compared to standard.
When you get a silicone TIP your car will peak to a couple more g/s and will run a bit higher in the rev range before your off boost, mine was about 300 - 400 rpm extra according to the graphs I did at the time.
If I was you, I think I would reduce the timing a bit and let the ECU adapt to the changes in exhaust air flow and boost pressure. Your car may make better figures now but the drive ability may be sacrificed a bit due to all the changes you have done without having a map to control it all. Let the ECU settle and upload the REVO stage 2 software then play around with the advancing the timing etc.
Im going REVO stage 2 in a couple of months and would be good to compare my results with yours.
Nathan
For sale
3" Downpipe and de cat (will be going on ebay soon)
Autogauge boost gauge
Chrome Audi Number plate surrounds
PM for info.
