Forge MotorsportBackdraft Motorsport
Results 1 to 13 of 13
    S3PEG's Avatar
    S3PEG is offline Neutral
    Bristol
    96
    Post Thanks / Like
    1999 S3 running lumpy
    I've put up with this for a while but it's got to the point that it's doing my head in.....
    at tick over the engine coughs and does the same when maintaining speed or pulling away (both using low revs) under accelleration or breaking the engine seems fine - no coughs or splutters til I come to a stop and the engine returns to tick over.
    No fault codes on the ECU and my local stealer checked the air mass meter/fuel system but reported no problems - I told them I'd leave it to the experts... please don't let me down...!!
    S3Peg
    Black S3, APR Chip, EBC Brakes, 18" RSTT's.
    Google Adsense Circuit advertisement
    Advertising world
    voorhees's Avatar
    voorhees is offline Moderator
    Dec 2005
    Leafy Warwickshire
    10,848
    Post Thanks / Like
    Coil pack, Spark Plug,Throttle body or Coolant temp sensor ?
    Quote Originally Posted by RevoKev View Post
    Sorry guys, I need to clarify some things here...
    When trial software expires it runs off completely stock tables although they are in different locations to the standard file... this causes a lot of confusion for those out there playing at tuning or those with limited tuning tools, thus all the BS and rumours out there. The fact that a main dealer can flash over expired Revo trial or any other Revo software says it all really!
    S3PEG's Avatar
    Bristol
    96
    Post Thanks / Like
    Thanks - I've recently changed spark plugs and coolant temp sender. I was also thinking throttle body and plan to give it a clean this weekend. Would a faulty/failing coil pack throw up an error code?
    S3Peg
    s3tle is offline 1st Gear
    239
    Post Thanks / Like
    Coil pack doesn't always throw a code on vagcom, if you've got vagcom you can log channels 15 + 16 i think. Get a friend to log those chanels whilst you go for a drive and they should see any misfires.
    S3PEG's Avatar
    Bristol
    96
    Post Thanks / Like
    Thanks s3tle - I'll give this a go.
    Just been reading other threads about a secondary air pump - could this come into play here?
    S3Peg
    karls s3 is offline 1st Gear
    Feb 2011
    southampton
    229
    Post Thanks / Like
    i have changed coil packs x4 plugs cleaned throttle body only thing i not done is coolant temp sensor do these really cause engine to run lumpy on idle
    audi s3 2001 amk 210bhp, forge 007p
    richrich14 is offline Reverse Gear
    Dec 2010
    29
    Post Thanks / Like
    Have you checked for splits in the PCV pipework? I had similar issues and has helped solve some of the problem.
    s3dave's Avatar
    s3dave is offline mediator
    west yorks
    6,187
    Post Thanks / Like
    with it been a 99 the SAI(secondary air injection) can cause problems and fill with water It can be deleted.....
    Quote Originally Posted by 16Klappe View Post
    And anyway, less of the thinking because I'm ALWAYS right!
    Feb 2011
    southampton
    229
    Post Thanks / Like
    sorry should have put car is a 2001. on the side of the block near tip there is 3 threaded holes and a hole in the middle with some thing in the hole blocking it. i used to own a ibiza cupra and a egr valve was in this place. didnt know if our cars have one.. engine code is amk
    Feb 2011
    southampton
    229
    Post Thanks / Like
    Quote Originally Posted by richrich14 View Post
    yeah near left of inlet near the valve i had split pipe that i put a hose over with two clamps
    s3dave's Avatar
    west yorks
    6,187
    Post Thanks / Like
    Quote Originally Posted by karls s3 View Post
    AMK has an EGT yes
    it should be fastened underneath the inlet manni
    Feb 2011
    southampton
    229
    Post Thanks / Like
    i know egt is under inlet manifold but not too sure on egr ill have a look also im not sure whats supposed to go on the side of engine where the 3 threaded holes are.
    Feb 2011
    southampton
    229
    Post Thanks / Like
    how do you know if the throttle body is faulty is there any way of checking
