Hi all,
Last week i posted about a problem i was having loosing all boost.
I found a possible culprit to this:
The image below (if i posted it correctly) is where i found a massive leak!
The circled pipe - the plastic one meeting the rubber one was not connected!
I'm not sure what this does (totally non technical) but i pushed them back together and used the jubilee clip to hold it.
After doing this instead of having no power i now get initial boost (perhaps a little late) and at about 3k revs sudden hesitation, it started as hesitation then boosting again after a second or so, now it seems to not quite boost 100% at all.
Pausing at 3k revs and picking up a bit but still not great.
The car is not running rough nor are there any problems under 3k revs driving normally around town.
Its just when you open her up!
I have a suspicion...
The pipe circled in the image below:
This whole pipe including the bit that was disconnected in the previous image is very spongy and highly warn... I dont know what it is or does (apologies for noob knowledge) But i believe this could be the cause?
What are your thoughts? could this be collapsing under pressure? (again i dont know what it does so maybe im wrong) or am i barking up the wrong tree?
Either way this is very weak and it needs replacing so any pointers as to where to get replacement or upgrade would be appreciated too.
Many thanks in advance
LinkBack URL
About LinkBacks
Audi S3
do away with all that pipework
