Results 1 to 14 of 14
    Aug 2010
    118
    boost pressure control valve mechanical malfunction
    hi, this is the fault on my s3 2001 amk. anyone had this? and is it a case of replacing the valve or there any ways round it??
    ash
    Aug 2010
    118
    is the n249 the boost pressure valve?
    Aug 2010
    118
    it says on diagnostics boost pressure valve malfunction (n249) so i have answered my own question there. does anyone know if i remove this and do the n249 mod will it stop my boost problem. problem being a loosing alot of boost intermittant. any one had similar problems?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Bypassing the N249 valve won't fix the issue entirely I don't think.... If the ECU stills thinks there is a problem with the N249 regardless of the bypass (as you would need to leave it electrically connected) then the ECU will still throw a fault code and do all the other stuff to protect itself like mess with fuelling and cut boost using the N75 valve....
    I suspect replacing the N249 for a working one (without actually seeing the fault code I can't say for sure) will have to be done regardless
    <tuffty/>
    Aug 2010
    118
    ok yeh, snap-on code is p1200 and reads boost pressure control valve (n249) mechanical malfunction. so i need to source i new valve by the sounds of it.
    Jun 2003
    west yorkshire
    90
    I had the same fault code on mine, changed the valve but still had fault, then about a week later a coil pack went, changed all four and now no fault code for the n249 valve, don’t know if a faulty coil pack could cause the fault or if it was just a coincidence
    Aug 2010
    118
    hmmmm?? how much was the valve? if the valve and coil packs arnt too much i mite change them all for the grin. where you get them from??
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    get coil packs from the dealer, prob an extra 20 over non standard but theres been loads of updates and OEM in this instance really is best
    the N249 will be dealer only....
    contact stoke audi or pjmspeedy off here as they will do them cheaper than your main dealer
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Aug 2010
    118
    al give them a ring monday. you say extra 20 is this each or for 4 thats 80 otherwise.
    Madeley's Avatar
    Jun 2010
    Telford
    125
    OE coil packs are about 30 each.
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    Aug 2010
    118
    are the original packs bosch?
    Aug 2010
    118
    Quote Originally Posted by chippie View Post
    i dont know wether to get the valve first and try that or get the coil packs first i can get the packs for 94inc vat and the valve 54+vat..decissions?
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Quote Originally Posted by stoneys3 View Post
    mine were Hitachi.
    Aug 2010
    118
    any advice on which to go for first? valve or coil packs?
