Volks AutosSky Insurance
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Inner CV Boot Replacement - Difficult?
    Whilst replacing loads of suspension bits today I noticed my inner cv boot on the passenger side is split
    How difficult is it to change on the S3? Does the entire CV have to be removed from the box or does it unbolt and split in two?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Removing the driveshaft is the easiest way tbh... easy enough to do... inner CV is bolted to the gearbox drive flange so undo a few bolts and its off... then you need to remove the circlip holding the CV joint on to the shaft and gently/evenly pull the CV joint from the shaft taking care as it could all fall apart if not held straight... make a note of how it all goes together and put it back together the same way...
    <tuffty/>
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Cheers tuffty, might rope my mechanic mate in to helping me I think. Bloody hate CV's
