Badger5Kowalski
Results 1 to 14 of 14
    Oct 2009
    150
    Post Thanks / Like
    hose/pipe help and info, with pics.
    hi, again. i noticed last week one of my plastic pipes had snapped clean off both ends with oil deposits around the connections. im not sure what the pipe does but the car appeared to run fine. i replaced the pipe this afternoon(pic 1), 35 quid! upon fitting i noticed, looking at the engine head on, at the bottom of the pipe there is a t piece then runs left to a plastic curved piece (pic 2, taken from my mates 20v golf) mine is not connected. it doesnt look like it has snapped off but it doesnt fit back on. could anybody enlighten me as to what this pipework does and if the disconnected pipe needs replacing or how to reattatch it. any help again will be very much appreciated.
    pic 1,
    pic 2
    sandip's Avatar
    Nov 2006
    Greater Manchester
    2,305
    Post Thanks / Like
    Sounds like it has broke bud, change 06a 103 213 f, are all you other pipes ok under the intake manifold, they have a tendancy to split
    I changed all the parts marked with a red dot, using both oem and Forge parts
    Oct 2009
    150
    Post Thanks / Like
    Good man I'll do the same, what exactly does it all do?
    sandip's Avatar
    Nov 2006
    Greater Manchester
    2,305
    Post Thanks / Like
    It's all to do with the crankcase breather system, it's mind boggling, some people have got rid of most of the stuff and gone for a catch can, i've opted to keep the oem set and just renew and upgrade the material of some of the hoses with these > Awesome > Forge Silicone Breather Hoses for the 225hp 1.8T
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    400
    Post Thanks / Like
    That is one hell of a good answer Sandip. wow.
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    Oct 2009
    150
    Post Thanks / Like
    So how much of it would be removed through the installation of a catch can as I was thinking if getting one anyway
    sandip's Avatar
    Nov 2006
    Greater Manchester
    2,305
    Post Thanks / Like
    I'm not sure exactly but i know that the pcv valve goes (058 133 753 B), basically by having the catch can there will be less chance of split hoses which means less chance of losing boost. Mine's done 123k on the standard hoses and by replacing the common spliting hoses for the more superior Forge ones i think i'll be safe for quite a while
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,864
    Post Thanks / Like
    or just check out the catch can thread and delete the whole lot
    Xbox 360 gamer ID : Timffy
    2000 Blue Astra 1.8 SXi - Sold
    1996 Burgundy (yup!) Escort 1.6 LX - Sold
    1990 Red Rover 214S - Sold
    sandip's Avatar
    Nov 2006
    Greater Manchester
    2,305
    Post Thanks / Like
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,864
    Post Thanks / Like
    great minds :D
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    262
    Post Thanks / Like
    brys3, do you know the part number for the pipe you replaced in the first picture as mine is breaking?
    also what is the easiest way to get underneath the intake manifold? take it off?
    2001 S3 8L AMK : Forge TIP, Red Dogbone, 16mm rear ARB
    239
    Post Thanks / Like
    it depends on engine code, if it's amk or bam i think the part is 06A103213AK
    Sign up to vagcat and check out the parts catalogue for yours
    VagCat boards (Powered by Invision Power Board)
    239
    Post Thanks / Like
    yon don't have to remove manifold, just the dipstick and metal plate which bolts to manifold and hold dipstick inplace, then you can reach under
    Oct 2009
    150
    Post Thanks / Like
    brilliant thanks, oil catch can looks like far too much effort
