Badger5Chris Nott
    S3 D2HTY's Avatar
    Apr 2010
    121
    Advice 1.9 conversion
    The garage rang me a told me the damage and it was the block needed to come out and be rebored.
    I am looking at going dwn the 1.9 route (83mm pistons)
    Correct me if i am wrong but i wouldnt be able to use the standard head gasket? What head gasket would i need?
    Also are there another bits i would need for the conversion?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    You 'can' use the std head gasket but the alternative is to use one from a non turbo 1.8 20v (Bill at Badger 5 runs a 1.9 20v is his Ibiza race car)... can't remember the part numbers off hand but some more info is available here:
    Lots of Big Turbo and High Power info!
    I personally wouldn't go above 82.5mm on a road car....
    I don't know what effect the increase will have on the fuelling requirements of the map but the ECU should be able to adjust to suit....
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,131
    82.5mm pistons are the max for std head gasket
    do you "need" to go 83mm?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,451
    83mm Pistons then you will need a N/A 2.0 20v head gasket
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    S3 D2HTY's Avatar
    Apr 2010
    121
    I was just thinking that while i am there. I might aswell go for the 83mm but if i can go for 82.5mm and stay with standard gasket i'll do that
    Cheers guys.
