Volks AutosEM Tuning
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    S3 / TT suspension part numbers
    I've just bought some TT Quattro rear shock for my S3 on the cheap as im fairly certain mine are past it and the knocking noise is becoming unbearable. Has anybody fitted TT shocks before ?
    Part number on the TT shock absorber is 8N0 513 025 K. I'm not 100% sure there going to fit but i will give it a go.
    Sean
    S3 Big Turbo
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    they should fit but let us all know the actual answer
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Yes i can't see any reason why they wouldn't fit considering they are almost the same car but i suppose you never know. They have only done 9,000 miles so once on they should be an improvement.
    Anything else that would be worth replacing while the shocks are off the car ?
    Sean.
    S3 Big Turbo
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by sean_s3 View Post
    Sean.
    Currently, I'm using TT front driveshafts and a TT prop - so as far as I'm concerned, most other things should work also...
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Just checked part numbers:
    The S3's rear shocks are 8N0512011H
    Same numbers, or there abouts, so I'd say yes.
    Homer Simpson
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Thanks very much , once there fitted i will let you know how i got on.
    Sean.
    S3 Big Turbo
