Results 1 to 7 of 7
    Nigma's Avatar
    Yakshimash!
    Aug 2004
    Cambridge, UK
    60
    Water leak / dripping in passenger footwell when AC is on
    Hi Guys,
    I recently had my air con re-gassed - and it was working great during the hot months. However, it freaked my wife out that when i switched the AC on, she would get drips of water on her foot in the passenger seat. Not a lot, but a small trickle. I don't think it's condensation - any thought what could be the cause of this ?
    Also, I'm not sure if this is a related issue, but the AC also suddenly stopped working the other day. Only seem to get "normal" temperature coming though. When i switch it on/off i can feel that the compressor is engaging due to the light drop in revs and pedel drops a tad.
    Any help would be much appreciated.
    Anand
    Audi A3 1.8T Sport - Black
    The higher the monkey climbs, the more you can see its arse
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    dunno about these but in most cars thats the heater matrix which causes the leak.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    XFi
    XFi's Avatar
    Jun 2010
    Grantham, Lincolnshire
    312
    Add XFi on Facebook Visit XFi's Youtube Channel
    Not too clued up on this sort of thing. I have heard that a pollen filter that needs to be replaced can cause damp/wet foot wells.
    Audi S3 8P3 Stage 1
    Aug 2010
    9
    most probably air con drain tube, has either come off or is blocked!
    Nigma's Avatar
    Yakshimash!
    Aug 2004
    Cambridge, UK
    60
    Narrowed down the problem after some investigation (Un-related to aircon being on)
    Turns out that the trim that sits between the windscreen and the car is not seated properly. For some strange reason, on the driver side it "clips" in but on the passenger side it doesn't want to stay in. I poured some water on the windscreen and saw water getting through and dripping onto the pollen filter.
    Can't imagine what other damage water getting into the ventilation system is doing.
    Other that using sealant, any ideas what i can do ?
    Thanks,
    Anand
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Was the pollen filter & cover fitted correctly? Just had a look at mine and i have a slight gap between windscreen and trim but have no issues with water getting in.
    Jan 2009
    149
    I have this exact problem. Its not the windscreen rubber dripping through the pollen filter. Its the aircon leak off dripping through the fan. I havent had the time to take it apart to investigate yet.
