Badger5EM Tuning
Results 1 to 17 of 17
    Ross_S4
    Aug 2009
    Dundee
    718
    Does this count as a boost leak?
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    YES
    Biggied's Avatar
    They called him mellow yellow.
    Feb 2006
    Scotland
    202
    I fear you may be losing a few psi & a couple of your ponies there Ross, will I tell Grant to expect a visit tomorrow lol
    OR you going for some silicone pipe? I know how u engineer types like to replace with somthing better when it brakes, not sure if you get a pre made kit or will need to just buy some of the same diameter?
    Ewan.
    210hp 8L S3 quattro.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Is there a tiny split in that hose
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I should coco.....
    Madeley's Avatar
    Jun 2010
    Telford
    125
    I was looking at these for mine.... Forge Motorsport | Alloy Fabrication
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    Jul 2010
    bristol
    647
    im suprised that doesnt put your car into limp mode, should be abit careful driving it while its like that, thats the feed for the n75 IIRC
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by Biggied View Post
    Ewan.
    Lol no not coming to see Grant this time mate, Autosave on Cleppie road had rubber hose in so I've just replaced it with that... So much for engineering!! I really really need to get that N75 loom extended and the N75 shifted round to the right side of the TIP.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Na, you won't get any boost loss through that..... Much.
    However, you won't have been getting any air to the N75 valve either for actuator control, so that may have helped to counter-act it.
    Homer Simpson
    Biggied's Avatar
    Feb 2006
    Scotland
    202
    See Ross you've been using up your "car fixing time" painting grill trims rather than the important stuff. lol Just cut the wires for the N75, use heat shrink crimps or solder to whack in an extension then wrap it with some insulating tape then fiber wrap tape to keep it looking factory. Audi do the fiber tape if u need it. If you don't do it I'm going to sneak round your house one night, take your keys and do it myself like a little car fixing fairy lol
    Ewan.
    S3KO4's Avatar
    Aug 2009
    London
    850
    IIRC when I had that it made the car run a bit funny and richer, I replaced it with the same size hose designed for fuel line that is much thicker.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    jack.s's Avatar
    Feb 2009
    east sussex
    119
    I had exactly the same thing and made the car go into limp mode when on boost to long, keeps happening and keep cutting it down but it's going to get a bit short soon lol think need to invest in a replacement silicone soon!
    Ming Blue S3 AMK . . .
    Ross_S4
    Aug 2009
    Dundee
    718
    Why didn't you say so sooner! you should've done it last night, when the car was sat in the drive all night unlocked with the ignition on 2. yep, that was one hell of a flat battery this morning...!
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by jack.s View Post
    mate save yourself some sheckles (unless you want it for the looks) cos I used 8mm rubber fuel hose, worked a treat!
    jack.s's Avatar
    Feb 2009
    east sussex
    119
    Yea I was thinking was that possible, I would much rather save the pennies right now! Lol where is the easiest place to get some 8pm fuel line?
    Ross_S4
    Aug 2009
    Dundee
    718
    any motor factors should have it.
    try this link
