Revo TechnikUnicorn
Results 1 to 18 of 18
    239
    Post Thanks / Like
    S3 Oil Breather pipes - seriously degraded!!
    Hi all
    I've recently got a '02 S3 BAM, and it has a slightly rough idle and seems to have a slight misfire at times.
    The car was on longlife til 70k miles then oil every 7k from then on. I decided to investigate the breather and vac lines to see if they were the problem.
    The oil breathers are in awful shape, can't actually see any splitts but they a basically collapsing and full of junk as is the PCV valve.
    Under the manifold i can also see one of the vac lines is spliting.
    I was planning on pulling all the pipes out and seeing if any can be salvaged and replacing the others, i see that Forge do some replacement pipes, but was wondering if anyone had any advise on parts to replace and other engine parts that might need cleaning/repairing as a result? or any other help would be really good!!
    DJ_Troopa's Avatar
    Audi S3 Driver
    Oct 2008
    West London
    1,679
    Post Thanks / Like
    I had this same problem matey. I changed mine to the Forge breather hose kit last week and everything is spot on again. You can even hear the car idle better! So much crap came off the old pipes it was crazy!
    I have a brand new Forge breather hose kit at home still all sealed up so if you want it you can have for £35 delivered 1st class recorded.
    Jay
    Lava Grey 2.0 TDI 140 Sport
    239
    Post Thanks / Like
    Hi Jay, yeah i was actually quite shocked how my crap there is inside them, i was just taking them off to have a look what i need to get, but can't bring myself to put them back on the car!! think i'm gonna leave it tucked up on my drive till i get the new pipes. Are the ones you've got for sale the kit with three pipes or the cam cover breather one? found the 3 piece kit for £28 delivered
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,474
    Post Thanks / Like
    Troopa, what colours the kit?
    Common fault with these cars, your better off replacing all rubber based pipes with silicone, all breather, vac, boost lines.
    barters3's Avatar
    May 2008
    440
    Post Thanks / Like
    I had to replace the vac pipe arangement under the inlet manifold.
    part no. 06a133789
    £57!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,474
    Post Thanks / Like
    Why didnt you just use silicone barter? Alot cheaper and will last alot longer!
    barters3's Avatar
    May 2008
    440
    Post Thanks / Like
    there were quite a lot of tight bends and there were a few fittings that looked like they could have been non return valves or something. Just laziness really, iv no doubt that it could be made cheaper and better quality out of generic silicone, i just couldn't be bothered!
    Im going to check out my oil breather pies after seeing this.
    239
    Post Thanks / Like
    Cheers guys, gonna go and finish pulling them out in a minute. I was planning to do the oil breather in silicone, but was thinking same a Barter and replacing the whole vac oem assembly (thanks for the price!) when it's all out i'll see if it would be easy to do in silicone
    DJ_Troopa's Avatar
    Audi S3 Driver
    Oct 2008
    West London
    1,679
    Post Thanks / Like
    It's the 3 hose kit as found on the Forge site. The hoses are only available in black. You can hardly see them because they're hidden underneath the inlet manifold.
    This is the link for the exact ones i have from Forge...............
    Forge Motorsport | Alloy Fabrication
    barters3's Avatar
    May 2008
    440
    Post Thanks / Like
    the forge kit looks a good shout, however the hoses which the forge items replace weren't split on mine, it was split elsewhere.
    Madeley's Avatar
    Jun 2010
    Telford
    125
    Post Thanks / Like
    Do you get the plastic thing in the middle as well?
    S3 2000 AMK car with a APY engine, minge blue, rs6 alloys and Revo'd by Badger5
    DJ_Troopa's Avatar
    Audi S3 Driver
    Oct 2008
    West London
    1,679
    Post Thanks / Like
    Quote Originally Posted by Madeley View Post
    It's just the silicone hoses you see in the pic. You already have the plastic thing where the breather hoses are in your engine.
    239
    Post Thanks / Like
    ok all out and have cleaned up the rigid pipes which i can re-use, so i'm going to replace all the rubber parts and valves in the oil breather system. Not 100% sure about the under manifold vac, only one pipe has actually split, but if one has i'm sure the others will fail soon.
    Parts needed
    Lower pcv t-joint 058103247A
    Lower pcv t-joint valve 035103245A
    Upper pcv, pancake valve 06A129101A
    under manifold VAC 06A133789
    Forge 3 piece oil breather kit
    Forge Cam cover breather
    16mm dia 250mm long silicone hose
    @ Dani_B19 have you redone your vac lines in silicone? i was wondering what to do about the joints as you'd be changing rigid pipes for flexible?
    239
    Post Thanks / Like
    Ok i'm now thinking about deleting the VAC lines and also fitting a catch tank, the cost of the oem bits is stupid, not sure it's worth replacing, if the catch tank and deletion works well??
    thorsy22's Avatar
    Jul 2008
    West Sussex
    308
    Post Thanks / Like
    For the vac system look at doing the n249 deletion, only takes a metre or so of 3mm or 4mm ID silicon hose. I'm looking at doing the oil catch can too, to simplify that system as well and prevent oil vapour going into the intercoolers, especially when I go FMIC.
    2001 Audi S3 - AMK 210bhp
    Tarox F2000 discs front - Tarox 401 Rallye+ pads
    Tarox F2000 discs rear - Tarox 112 Strada pads
    Goodridge brake lines
    TT pedals
    N249 bypass
    Finally back on the road, have a HUGE list of mods and things to do now!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    5,474
    Post Thanks / Like
    Yes mate, all my vac lines have been redone in 3mm red silicone, also did the n249 bypass while i was at it.
    239
    Post Thanks / Like
    Thanks Thorsy + Dani
    Yeah i guess i'll do the lot while it's off the road, only had it on the road for 6 days!!! still find it hard that it ok just to delete these things!!
    Looking for a catch can similar to the saikoumichi one, which has the baffles etc, can really wait for delivery from US, not sure yet if the greddy or forge have the same design...
    The Doctor's Avatar
    Jul 2009
    Nottingham
    799
    Post Thanks / Like
