Results 1 to 11 of 11
    Jul 2010
    Birmingham
    66
    knocking sound when going over potholes humps
    MY a3 has strated making a knoking sound when going over humps and pot holes there is a slight noise coming from the front but somtimes get a very loud knock from the back i have changed the rear top mounts the arbs look ok has any1 else had this problem
    colicabcadam
    bit silly, but are your tyre pressures correct?
    Jul 2010
    Birmingham
    66
    yes there correct could this knocking be caused by worn rear axle bushes
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    What sort of A3, T Sport or Quattro?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    14
    Check that the front ARB plastic collars (assuming it's an original ARB) haven't fallen apart. All your exhaust mounts are ok as well?
    Jul 2010
    Birmingham
    66
    its a 2002 standard a3 tdi 130 SE arbs have been checked and seem ok
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    wish bone bushes
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,369
    Shocks
    Jul 2010
    Birmingham
    66
    ok thanks il have to have a look i have asked a VAG speailist and he thinks rear axle bushes but will ask him to check the other stuff
    Lloyd149's Avatar
    Dec 2009
    York
    102
    Knocking sounds are usually bushes, previous car was a Ford and that is their most common problem.
    Jul 2010
    Birmingham
    66
    the problem was rear axle bushes
